Rust on towball
Jun 3, 2025
24
15
Hi! We are about to head off on a trip and there is a bit of rust on the towball which developed in the few days it took for the new cover to arrive when the previous one was mislaid. Should we give this a little sand before hitching on and, if so, what grade of sandpaper should we use? Thanks so much for any advice!
Sam Vimes
2,524
2,027
12,935
I use a 120 grade Emery Cloth then give it a spray with Brake Cleaner fluid. I also spray up into the hitch point on the caravan.
Reactions: Didi
4,002
1,750
As it "developed in a few days" its only superficial and does not need so aggressive attention of abrasive papers, these are best avoided for all but serious rust removal.
As already advised in #3 a firm wipe with one of the 3M or similar aluminium oxide filled plastic mesh mat type pan cleaners is all that is needed, or as Lutz said you could just see if it wipes off with a rag cloth.
It is best removed because if not it adds to the fouling and glazing of the friction pads, reducing their useful life and adding to squealing issues.
Apr 13, 2021
188
141
4,635
On our last car we had a drop down towball that locked up sideways into the bumper and it used to catch a lot of water and was even worse with a cover on so I was forever cleaning heavy rust off the thing, and then as Buckman says finish it off with brake cleaner (up onto the pads as well)
On the Kuga that we have now the ball comes out electrically and I think that it must be made of a chrome alloy (maybe not quite stainless) because it is permanently like a shiny new pin.
Love it to bits.
Reactions: Didi
