Rust on towball
Jun 3, 2025
23
Hi! We are about to head off on a trip and there is a bit of rust on the towball which developed in the few days it took for the new cover to arrive when the previous one was mislaid. Should we give this a little sand before hitching on and, if so, what grade of sandpaper should we use? Thanks so much for any advice!
Nov 30, 2022
1,937
1,814
2,935
A bit of fine glass-paper (sand hasn't been used for decades) or a bit of fine wet and dry (used dry) will do the job perfectly.
DONT use anything coarse
Reactions: toad a caravan
Sep 23, 2023
1,329
571
2,435
A yellow foam pan cleaner with a patch of green abrasive should work ok without reducing the dimensions of the towball,please note other colours are available 😁
Reactions: JTQ
Sam Vimes
2,521
2,023
12,935
I use a 120 grade Emery Cloth then give it a spray with Brake Cleaner fluid. I also spray up into the hitch point on the caravan.
4,002
1,747
As it "developed in a few days" its only superficial and does not need so aggressive attention of abrasive papers, these are best avoided for all but serious rust removal.
As already advised in #3 a firm wipe with one of the 3M or similar aluminium oxide filled plastic mesh mat type pan cleaners is all that is needed, or as Lutz said you could just see if it wipes off with a rag cloth.
It is best removed because if not it adds to the fouling and glazing of the friction pads, reducing their useful life and adding to squealing issues.
