I deduce you must have a hot water circulating system, most likely an Alde space heater system. I am not familiar enough with this make of product to offer specific advice. The heating system may need a service - when was it last given one? apart from that I'd agree with the other replies and it might be wise to make sure the system is bled and properly topped up. You should have the instructions in the heaters instruction book. I don't know whether you can increase the circulating waters temperature, but apart from those points without increasing the size of the radiator in the bathroom I cannot see another way round it.Second question towel rail in the bathroom insufficient for heat in the bathroom anything to increase the heat in the bathropom.
As this was your first question and the title of the thread is S2 Barcelona Noisy Water Pump, I presume you are referring to the cold water pump for the taps. This almost certainly means you have an inboard diaphragm water pump e. Unfortunately these are inherently noisy compared to an external submersible pump. If this is the case then rewmounting the pump into a rubber pad to insulate the pumps vibrations from teh body of the caravan might help.We have a S2 Bailey Unicorn Barcelona and the pump has always been noisy any advice to quieten the pump.
Hello Phil.
Can I reverse your two questions.
I do know of one person who changed the internal pump for an external one that drops in the water container, but they also had to purchase the side wall fitting and a pressure switch to make it all work.
Just to add that I am not aware that the ALDE system would require a service so maybe it is not necessary however a good idea to change the fluid from the 2 year to the 5 year.
This link takes you to the ALDE system and you may be able to expand your knowledge if you download the manual for the 3020 system. See https://www.alde.co.uk/manuals-and-documents/ Hope it helps.
Past experience regarding noise is pump on 5 instead fo 2 and air in the system which is why bleeding is probably the firts step. We had this issue on our 2011 Lunar Delta.
You are correct that over time gas appliances need servicing however the gas service is not part of the normal service and is an extra. I would think that most people use the ALDE system on EHU so the actual ALDE system would not require servicing. There is no need to change the fluid for 5 years.All gas appliances over time may need a service. The manufacturer will normally suggest an appropriate schedule, to ensure their combustion tract and gas supply and gas air mixing systems are clean and working correctly, and especially those that are only used intermittently or stand inactive for weeks on end. Because of the conditions that most caravans are kept in, many appliances will deteriorate whilst being unused almost as quickly as wearing out from use.
Changing the fluid is a service activity!
Thank you for pointing out the documentation. However since I have retired from this area of work I have no intention cluttering up my PC with this documentation, especially as the OP has not specified a particular model which might well be different to the one you have suggested.
Like Damian I am not sure the OP's pump question relates to the heating system. Based on the title of the thread, it seems more likely he is referring to the cold water supply pump.
It would be more helpful if the OP could enlighten us please.
