Can you have a sat nav that is caravan friendly , ive heard of sat navs that send lorries etc down narrow loads , low bridges
Steve,I have to agree with John here on the maps.
People put too much credability in a sat nav and forget the age old technique of map reading. It won't be long before someone call's the AA or RAC to say they can't move because the sat nav is broken.
I have 2 sat navs but still use a map for reference to check that, (A) the sat nav has found the right place, (B) that the route is as practical as possible, (C)use the map as back up when the sat nav fails.
If you set any sat nav to truck on the vehicle options, it will generally take you along main trunk routes and only deviate to narrower roads if there is no option. But, by tracking the route with a conventional paper map you can often save distance by using a B road to interconnect with the trunk roads.
Common sense has to prevail with what ever mapping/guidance system you use. I have twice been advised to navigate a roundabout anti clock wise !!?? by tom tom. Needless to say I looked before trusting the gizmo thta was blatently wrong!!
Sat navs are good tools in general, but they and maps should not be used to replace driver knowledge and common sense.
You wouldn't drive down the slipway to aferry that isn't there, or would you?????
Atb Steve.
