Can anyone recommend a reasonably priced and effective sat nav that covers Europe ?
Many Thanks
PETERA
Many Thanks
PETERA
MY tom tom 750 takes vioce commands, and i would be surprised if it was the Only one to do so,many sat navs come standard with blue tooth, and again mine comes with the ability to be herds over the radio, although i can gear it OK in its norm, and I don't have the best hearing anyway.Uvongo93 said:Can any of the Tom Tom's have their audio routed through the Bluetooth system in the car so that you can hear it over the car speakers similar to using a mobile phone? I don't suppose any Satnavs take voice commands. We have an Nokia X6 which as Satnav on it, but it is more for walking around as you cannot see ahead when using it in the car and have to rely on voice instructions.
After we lost ours and reported it to the police, they gave me a device to put the sat nav on.steveinleo said:Sorry to hear you had your satnav nicked Clive.
A point to consider is how a satnav is fitted in most cars. The obvious thing is to use the suction pad adaptor. When the sat nav is put away, folks leave the sucker on the winscreen or if they've put that away, a circular ring is left on the screen, thus giving the game away that there's a nav in the car.
I used to site my Garmin at the top right of my windscreen so I could see it while driving. On the outside of the screen I put a sticker, large enough to cover the suction base of the mounting. This hid the give away sucker ring.
On my Rover 75 I utilise the pop out cup holder on the center console. I made a dummy cup out of wood and glued a plastic disc to the top of it to form the base for the satnav bracket.
There's just a couple of ways of mounting satnav's without giving the game away.
After all, they are an expensive gadget.
Satnav's are great tools but they are only as good as the info put into them. Hence why some caravan sites give a different post code to their address, to guide your satnav better than the post office service.
! have both tom tom and garmin, tom tom 750 garmin c 550.and the tom tom can be set up to warn you in advance of possible change of lane or turn, upto 2 miles in advance!. have trouble with both in centre London in the build up areas, although this doesn't happen every time, but you simply learn to remember you are taking the next or 2nd turn as it arrives in view.OmOnWeelz said:Prob with factory fit satnav is that often the expensive system does not get covered when the car is traded in and often they are expensive or difficult to update with new mapping or extra detail.
Garmin update mappping 4 times a year now so if you've not updated it Collin that might help. Wife has a newer TomTom that is very good but my Nuvi gives better warning time before telling to turn. With caravan in tow last minute instructions are not good and quite a few review reports complain that TomTom software gives turn instructions a little late.
Age and spec of Satnav make a quite a difference, Budget end basics don't give all the options of the top flight models.JonnyG said:have trouble with both in centre London in the build up areas, although this doesn't happen every time, but you simply learn to remember you are taking the next or 2nd turn as it arrives in view.
Philspadders said:Any one with a nokia smart phone can download ovimaps for free and you can sync your phone to a pre planned route ( download ovimaps to your pc and you can select a route or routes and stored them in your phone for later use).
The ovimaps recalculates routes faster than anyother system and considering is free, its not bad. It can use GPS or assisted Gps or just the mobile network if you want.
not sure i get any of these quotes? "recalculates routes faster than any other" who said? nokia? my tom tom is slow at times but its maping engine is working out live routes and hd info, so its doing a lot of recalucalating. My old garmin which did not have these featurers was quick very quick to recalulate. its all down to the mapping engine.nelmo said:Philspadders said:Any one with a nokia smart phone can download ovimaps for free and you can sync your phone to a pre planned route ( download ovimaps to your pc and you can select a route or routes and stored them in your phone for later use).
Problem with that is you need to have a phone signal - get to an area of bad or no signal (like round most campsites) and you've lost your navigation abilities.
My satnav is on my Nokia but installed locally, so can be used anywhere, regardless of phone signal.
