I am thinking about purchasing Humax HD freesat reciever- are they suitable for caravaning and what are they like to set up??
Thanks, JD
Thanks, JD
hi Birdmanbirdman101 said:The only problem i have found is the sound goes out of syncronisation with the picture which i have to adjust on the settings.(bit of a pain all the while,thinking of changing it .Dont have this problem on my reciever at home)
TonyG said:hi Birdmanbirdman101 said:The only problem i have found is the sound goes out of syncronisation with the picture which i have to adjust on the settings.(bit of a pain all the while,thinking of changing it .Dont have this problem on my reciever at home)
I have never experienced this, however if your sound is out of sync with the picture, could that be a signal issue rather than a faulty reciever... just a thought
I have used another reciever on same set up and sound is fine, but the other box is not HD .I always get the max signal when setting up ,i use a signal strength meter and also look on screen menu.I have even put the box on my home dish and it does the same,whereas my home box is fine.Will be buying another LG box for caravan use.
