Good idea but I use 2 clamps. They are spaced as far apart as possible. If the jockey wheel shaft is set high, they are fitted above the A frame. If the jockey wheel shaft is set low then one of the clamps is positioned above the A frame and one below or both below the A frame. This allows the mast to be clear of the ground and so be raised higher.
