Sharp 24" Caravan TV - WiFi connection issues
May 20, 2024
13
13
515
We bought one off these Sharp TVs for the new caravan and whilst it works very well when hooked up to the Antenna for DTV (excellent picture quality and good sound), we were unable to get it to connect to wifi hotpsots on either of the phones we tried to connect it to.
Does anyone have any advice as to getting the WiFi connection working properly, or am I going to have to bite the bullet and buy a dedicated mobile router for the van?
2,776
Does it connect to WiFi at home OK?
To check on the connection, will one phone stream off the other? I have heard that some data providers limit the phones ability to tether. Could this be the issue?
I cannot see why there should be a problem. We streamed using our phones in the van.
13
13
515
Thanks, yes the phones stream off each other. Have to admit that I haven't tested it at home. Am thinking it may need a wired connection at first then allow it to download an update, which would be infuriating..... But it would at least fix it.
Reactions: Jcloughie
Oct 16, 2022
33
7
1,535
I got a sharp to took me a while to sort out I use a HUAWEI dongle and it works great you can put any SIM card I use a smarty
Oct 16, 2022
33
7
1,535
I just kept trying until it excepted the net work you might find that the network you want is greyed out but it has conected
May 20, 2024
13
13
515
Finally coming back on tis one, having had a chance to work out the issues.
The TV connected to my home network without any issues, so we tried with a different phone, which it also connected to.
When we tried to connect to a Samsung, we realised that this was the cause of the problem. Home and second phone used WPA2 security. Samsung used WPA3, which the TV struggled with.
So for anyone else getting one of these, make sure that any wifi uses WPA2 not WPA3 security!
