I own a 2004 Swift spec Abbey Impression 520L caravan. It has an internal tank with pump as well as the external normal fit pump and water carrier.
The lift pressure is dismal on the standard pump system so I decided to put in a sureflo. I have a problem though.Because the internal pump allows water both ways I cannot simply replace it with the Shurflo. The only way I can see I can use it is if I put a series of valves in to switch the flow and put another pipe into the internal tank. Alternatively put 2 Shurflo pumps in, one for the external lift (in this case will it draw through the wall unit and external pump, and one to pump out of the internal via another entry, as the external fills the tank by passing the water through the internal pump.
Maybe I can use some solenoid valves to switch the flow, but I am pretty confused at the moment
Has anyone ever done this?
