Solar Panel
4,152
1,884
The currents from the panel are not of importance as these are not at the lower voltages the controller outputs to the battery. A half decent controller will output quite a lot higher currents than it receives from the panel.
Watts is a multiplication of Volts and Amps, so if you divide the Watts you are handling by the lowest voltage you could ever be at it gives you the maximum current [Amps] handled. So lets us take a bright sunny day with a pretty depleted battery keen to receive anything going. Than could mean it is way down at 12.5 volts maybe lower.
So 160 Watts divide by 12.5 Volts = 12.8 Amps.
As the battery gains charge this progressively moves up to 14.4 volts, so the current drops to 160/14.4 = 11.1 Amps
So the controller is overloaded; the only thing saving it will be some cloud etc where the panels yield could be much lower.
Morningstar do make excellent controllers , both mine are, but they are far from the budget priced unit being shown here.
Yes you need to select by amperage and to be safe use 12 volts as your reference; so in this case with 160 Watts of panel look for at least 160/12 = 13.33 Amp unit.
Apr 28, 2011
506
I have just managed to get one of these on ebay for £15 with postage
http://www.maplin.co.uk/p/12v-30a-solar-charge-regulator-n28kr
2,400
johnandrew70 said:
Thanks for the Advice Parksy out of curiosity how thick is the sandwich construction of the roof (2007 Swift)
i did wonder weather to fill the entry gland with sikaflex to make double sure no water will get in.
About an inch or so if I remember correctly John. Take care when cutting through that no 12v cables for lights, Omnivent etc are where your entry hole will be. Start the hole gadually for a neat finish, the insulation is easy to cut and take great care with the aluminium outer skin. The more Sikaflex the better to seal the grommit and entry gland to make them watertight, it's not as though you will be taking it off again
Apr 28, 2011
506
will use a small hole saw on slow speed inside and keep checking there are no wires there, Can you tell me which Sikaflex is the best i have been on there website but they all seem to do the same job.
I have found one of these for the inside of the van to make it nice and neat.
http://www.ebay.co.uk/itm/CABLE-ENTRY-COVER-BLACK-SOLAR-SATELLITE-AERIAL-AIR-CON-WEATHERPROOF-SIDE-WALL-/231105747786?pt=UK_Campervan_Caravan_Accessories&hash=item35cef9db4a
I used SIKA252 to stick the brackets down with and SIKA291 to stick the cable entry gland down with.
I noticed the panels are 92 cms in length, i fitted the extra brackets along the sides for extra supports and increased stick down area
data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4R6yRXhpZgAATU0AKgAAAAgADAEOAAIAAAAgAAAIqgEPAAIAAAAWAAAIygEQAAIAAAALAAAI4AESAAMAAAABAAEAAAExAAIAAAAMAAAI7AEyAAIAAAAUAAAI+AITAAMAAAABAAIALodpAAQAAAABAAAJDJybAAEAAABAAAAbeJyfAAEAAABAAAAbuMSlAAcAAAKyAAAb+OocAAcAAAgMAAAAngAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAE9MWU1QVVMgRElHSVRBTCBDQU1FUkEgICAgICAgICAAT0xZTVBVUyBJTUFHSU5HIENPUlAuAEZFMTkwL1g3NTAAAFZlcnNpb24gMS4wADIwMTM6MDQ6MTcgMTc6NTM6NTgAACSCmgAFAAAAAQAAEs6CnQAFAAAAAQAAEtaIIgADAAAAAQAFAACIJwADAAAAAQBQAACQAAAHAAAABDAyMjGQAwACAAAAFAAAEt6QBAACAAAAFAAAEvKRAQAHAAAABAECAwCRAgAFAAAAAQAAEwaSBAAFAAAAAQAAEw6SBQAFAAAAAQAAExaSBwADAAAAAQAFAACSCAADAAAAAQAAAACSCQADAAAAAQAYAACSCgAFAAAAAQAAEx6SfAAHAAAHzAAAEyaShgAHAAAAfQAAGvKSkQACAAAAAzAwAACSkgACAAAAAzAwAACgAAAHAAAABDAxMDCgAQADAAAAAQABAACgAgAEAAAAAQAACwCgAwAEAAAAAQAACECjAAAHAAAAAQMAAACjAQAHAAAAAQEAAACkAQADAAAAAQAAAACkAgADAAAAAQAAAACkAwADAAAAAQAAAACkBAAFAAAAAQAAG3CkBgADAAAAAQAAAACkBwADAAAAAQAAAACkCAADAAAAAQAAAACkCQADAAAAAQAAAACkCgADAAAAAQAAAADqHAAHAAAIDAAACsLqHQAJAAAAAQAADcYAAAAAHOoAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAAGQAAAAB8AAAAKMjAxMzowNDoxNyAxNzo1Mzo1OAAyMDEzOjA0OjE3IDE3OjUzOjU4AAAAAAIAAAABAAAAAAAAAAoAAAFGAAAAZAAAAD8AAAAKT0xZTVAAAQAZAAACBAADAAAACggAAAECAwABAAAAAQAAAAICAwABAAAAAAAAAAMCAwABAAAAAAAAAAQCBQABAAAAFggAAAUCBQABAAAAHggAAAYCCAAGAAAAJggAAAcCAgAIAAAAMggAAAgCAgA0AAAAOggAAAkCBwAgAAAAdggAAAADAwABAAAAAAAAAAEDAwABAAAAAAAAAAIDAwABAAAAAAAAAAMDAwABAAAAAAAAAAQDAwABAAAAAAAAAAYDAwABAAAAAAAAAAAPBwDoBQAAlggAAAAEAwABAAAAAQAAAAEEAwABAAAAAgAAAAIEBAABAAAACVAAAQMEAwABAAAAAgAAAAQEAgAMAAAAfg4AAAUEAgAKAAAAig4AACUCAgADAAAAMDQAAAoCBAACAAAAlA4AAAAAAAAAAAAAAAAAAAAAAABkAAAAZAAAAPobAADoAwAAqP/h/nz+pf/a/nT+RDQzMjcAAABbcGljdHVyZUluZm9dIFJlc29sdXRpb249MjFbQ2FtZXJhIEluZm9dIFR5cGU9U1g4NzYAAAAAAAAAAABPTFlNUFVTIERJR0lUQUwgQ0FNRVJBAP///////////wAAAAAAAAAAAAAAAAAAMDAAAAAAAAAAABlhEjEAAAwSAAAnmAAAC4QAABcIAAAXCAAAAAAAABfQAGQAvQBQHyAAAAAAAAAAAAAAAAAAAAAAJygOAwAAAAAAAAAAAAAAABsmAAA8ABFRAAAAAAAAAAAAAAAAAGQLhAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABEREREBBAO0A+wBAAIAAmcBQwIAAQJgWgABA1IAEAAYABAAGAAQACsAAAAAAAAAAAAAAAAAAQAAAL0BZQINArUDXQAAAT8CAAI2AAAQSBC8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIiIAQAD9QAAAAAJFgAAA+kAAAAAAAGGoAAAAAMAAAAAAAAAAAAAAAAEFARFBEUD7dAAA/UAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM3w1NDOYLtgAAAAAAAAAAIQYh1yBzHDIAAAAAAAAAAHd3d3cApAEwAKIBLnQASy4AAGQAS1kAAAHuAUACpgFnAmcBQyAAAAkAAAAAAADFEgAAAAAAuQE7AIwA4QEEAVQMAAEEACAACgCxAS4AsQE9ALEBPQAbZAAOAgMAAAAAAH0OAAALEAhFAzgIlQAoAAAAAAAAAAAAAJmZr9sAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABgMAAAAAAADQ4Oz0AAAAAK/bAAP//////////wD//////////////wzfDU0M5gu2AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAA//8AAKqqqqoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALAAgACAAIABkAAAAACjfAAAfUwAAAgAAZAAAAAAAAAAAAAAAAAAAu7u7uwAJBBQERQRFA+0AAAAAAAAAAAAAAAAAAAAAAvsDHgMhAuIAAAAAAAAAAAAAAAAAAAAABF8EPQQIA5gAAAAAAAAAAAAAAAAAAAAAAZ0BwAHdAbgAAAAAAAAAAAAAAAAAAAAAAo4CmAJjAhoAAAAAAAAAAAAAAAAAAAAAAZgBvgHhAb4AAAAAAAAAAAAAAAAAAAAAAnICiAKNAkgAAAAAAAAAAAAAAAAAAAAAAY0BjgGAAWwAAAAAAAAAAAAAAAAAAAAAAycC+QKsAkwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzMzMzADIAZAAfQF3AJ8BLACWASwAAQACAC4ALAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3d3d3QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEwO5AQcALwADA6r/+AAN/+//6xBI//QAABC8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAUABwAAAAAAAAAAAAAAAAAAAAUAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAwMEsyMjAzNTM0NzgyAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgAAAAAAAAAABkTwBMAFkATQBQAFUAUwAgAEQASQBHAEkAVABBAEwAIABDAEEATQBFAFIAQQAgACAAIAAgACAAIAAgACAAIAAAAE8ATABZAE0AUABVAFMAIABEAEkARwBJAFQAQQBMACAAQwBBAE0ARQBSAEEAIAAgACAAIAAgACAAIAAgACAAAABQcmludElNADAzMDAAACUAAQAUABQAAgABAAAAAwDuAAAABwAAAAAACAAAAAAACQAAAAAACgAAAAAACwA2AQAADAAAAAAADQAAAAAADgBOAQAAEABeAQAAIABSAgAAAAEDAAAAAQH/AAAAAgGDAAAAAwGDAAAABAGDAAAABQGDAAAABgGDAAAABwGAgIAAEAGAAAAAAAIAAAAABwIAAAAACAIAAAAACQIAAAAACgIAAAAACwJ2AgAADQIAAAAAIAKOAgAAAAMDAAAAAQP/AAAAAgODAAAAAwODAAAABgODAAAAEAOAAAAAAAQAAAAACREAABAnAAALDwAAECcAAJcFAAAQJwAAsAgAABAnAAABHAAAECcAAF4CAAAQJwAAiwAAABAnAADLAwAAECcAAOUbAAAQJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFBQUAAABAQICAwMD//wAAQECAgMDA//8AAEBAgIDAwP//AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFBQUAAABAQICAwMD//wAAQECAgMDA//8AAEBAgIDAwP//AAD/4QwjaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pg0KPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyI+PHJkZjpSREYgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOnhtcD0iaHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpDcmVhdGVEYXRlPjIwMTMtMDQtMTdUMTc6NTM6NTg8L3htcDpDcmVhdGVEYXRlPjx4bXA6Q3JlYXRvclRvb2w+VmVyc2lvbiAxLjA8L3htcDpDcmVhdG9yVG9vbD48L3JkZjpEZXNjcmlwdGlvbj48cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0idXVpZDpmYWY1YmRkNS1iYTNkLTExZGEtYWQzMS1kMzNkNzUxODJmMWIiIHhtbG5zOmRjPSJodHRwOi8vcHVybC5vcmcvZGMvZWxlbWVudHMvMS4xLyIvPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIj48ZGM6dGl0bGU+PHJkZjpBbHQgeG1sbnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj48cmRmOmxpIHhtbDpsYW5nPSJ4LWRlZmF1bHQiPk9MWU1QVVMgRElHSVRBTCBDQU1FUkEgICAgICAgICA8L3JkZjpsaT48L3JkZjpBbHQ+DQoJCQk8L2RjOnRpdGxlPjxkYzpkZXNjcmlwdGlvbj48cmRmOkFsdCB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6bGkgeG1sOmxhbmc9IngtZGVmYXVsdCI+T0xZTVBVUyBESUdJVEFMIENBTUVSQSAgICAgICAgIDwvcmRmOmxpPjwvcmRmOkFsdD4NCgkJCTwvZGM6ZGVzY3JpcHRpb24+PC9yZGY6RGVzY3JpcHRpb24+PC9yZGY6UkRGPjwveDp4bXBtZXRhPg0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICA8P3hwYWNrZXQgZW5kPSd3Jz8+/9sAQwADAgICAgIDAgICAwMDAwQGBAQEBAQIBgYFBgkICgoJCAkJCgwPDAoLDgsJCQ0RDQ4PEBAREAoMEhMSEBMPEBAQ/9sAQwEDAwMEAwQIBAQIEAsJCxAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ/8AAEQgDAAQAAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A/Lwu4BCA9Oagxyc456VoTXG1NohXkEEkZzWe5yc+tZoVxYgSflGfXmrDNDJHg5V8fgaigRXbltpxxViSzxCXHVTSbV7MTKB64Pam8dM05xwKYTVghwXPBphXB5NPUkU5AhyWz7D1oDYYvAHv+tO3ED5hkelADDkDj0oBYkY/WgBA3zfL0qeR4ZTuSLYD2FVyGU9Dml34XaM470WAkBIyFJIpZJC67TximI+1QRwRTxtbtgjmkDGbdpyTzT0HOd2B1z70rRfIHB3c0Rj5GUjGaAJY4HdyUcfietSBQHUggEc4JqqhKkcf0rVthESUZlVTjG/1+tLYC7bSW5QiUMzDpnpn6VA/zxhvLJO77x/lRM5tiBu3gjhge9MNxIySOzcjAxjqDWXLZ3Qc1ixcvORmV1+U4Bz1qu+8wiXOByOn50xnMuFmYhQOfatKw0/fotxqLXcRSJwohY/MwPUgflQ7QWotZGfCfKjDhmBY8/SpBMnRhuxwOaiCwi2OSfPJBUdgKrs0kZ3AkGqE1cuM9xErERlVz6d6igmLOu/gA5J9qb9sdrbyi+QTkj3qMxyIvzcZo9QLk93FM2UjAUcKCc4FS2twpCq79OTmqKALB/tMcfhU0EMjOEYgMzAcnpUPRBY63T9RRUU7uemD2FaqXqn5jMufSuNmDWcpiVt2043LyD9KtC5llVScLgY9OlZc7WprGpJaHZRSO+NsqNn1NOcTAkkZHqK5NLtlG0fez1zV6yuXmTbLcMMfdA6GqjO/Q2VRvdG2zSEDA/Kn/ZpnH7xQuePeqltf+UAp6frVj7YZQSGAxzya1V+xblGxMlkmcSKfqx/pRLAVVdjrgdABUBmfqH4/nT/NlGCHUA1SQnO+g0xS5wZPakEBByQOalJlI3FutK
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
OtTGRVwdxAzSE7oZIeMcmobxskADAFWFWPcCWJ9Aaq3gxLj0prcT0WpWIH+RU9gN1yo9SKg68Vb0lc3QyM45Aq3ojK15WEngEMhQSBlAzle9QtuiTHXPX6U4knHzcd6klDeUCIwAOM9ai5mUCDuIA69KGTjoTj9KnC4kBIOBTmQqd3U/wA6q4yKLci428HnNKEz1qRUkfoOlPSPPBBpXEQlV6YNONupA2/WrUcJc5qwunTKiynlTU89hqLexmCALguQT7ClCrnithrW3MSogIz3xSHTLcIPLcb+cg0vaIv2bMcJ/CBSeWcjtk8VtLpyKoJ4DDg+9H2dIMgMgByMjrR7RAqbIo9FEUcdxeyqivyFB+ZhRNFZsB5EHlhR1ySTU728r7SZN2BwTT7eGNmaNsHPAqb9Wy1TK6rGpBPPtUsRCnO3A7HPNWDZhWCMVB6kDmnR2QbBGMDqKeha2sR5Z23MdwHOOn6UqwxtuYZBzxj0q4tskagqevUVOkSoM446YppdhO60ZUWGTgA4q5DaXLg5iIBPXpShQpDKGGKm86VcYc8nmqsLmJ4dMBBErHOc8VetrG2gO484Hb1qh9qaNNokbk8jFA1CReA5PT8aTTY1JXNuOJCA42+mO9Es8UPJfkcHmsmK4vLpisanjjpirHlWsSN/aNyQ5HCjn86VlcbbaLLanAseIgzNnv0qubi/vRiMH3GMfrUV9rGl2oQWFuSAuGaTrmsm58Q3UinbIyj0XiqS8iHLzNdrLaN13dIgPr1qI6lp9qmIojKy924zWEZ7m56Bjmp4NKmmO95UUdPcfWjTqCb6Ghc+J7y4jESlUUcAKMYFZErz3B8zJYjoK3V0uEW6QARkg5Ln730qzb6XHlRMRt9qSdtkU4pvVnPR6RNKUeSZQGHQcn8avx+HYOGeRz356V0S2MMZxCp9jjmrccPm4O1c4wCaNSmoW0MaDw/bLtcYwBxjvV+LT4YxgLuNaCxKMZHQ1KqgNwMY5o5Rc1titDbgDITj+tTrhVBC+2akCHvTgFTn0qrJC23EVT16jHenbQv4e9JvbGfy9qayu3JBxj1oHcdvRcAc5pu+TJ4xmkMTYBz3605Yyg2k8kd6NydSMhvvkk8dzTdzE42cfpUpWMHOcn0xQQ5OFQYPrTBDVRec5xQUIYhf/rYpfKkORhcjpg09fM6j+H9KAGopJ+YcinqMr8uPrSxRtk7j7EClCsDnbSC9gYN1PA+lJsw2NpPcccU8JyQeR9OlOAXuuQOeaB7jTuIzjr60qr3C5JFSDcRwnSmFWZTkZB9qASew0O4BAAxRubeTnFK2QN2OO/FBY98Z6UFLYAzAEZBxSF9pzgnFBLEg54xmmq6birDB7Gi4DtzsCfu5peNvD80itG4J3cjPQ1A1zbRHa8yjPYmi5LLOcHkcimFjyAo9zVO6kMcZngYMR8xAPUVaiurfy1cyDLDOM4pJlJq1hfLfPIBHrS4KkZXvSNdwchXBIGetVbXVrO7do4nyw6+1O6JTXctcdAaQjIIweKZPMiD5lypPNKsqZxg46mhC6ijaDz39O1NLhAcdD0pk95bLkmTp2pqzxsck/iTTG9R3JHIyD6UFFU88mmmaNAWDLzUTuX4z+VAk0iYbcgZOMfrSjyiu3acmquGIwoyO+KliillYJtct02r1pBqyykkSZBH44ppZ5TsiXP0rRs/DjsomvJ/Kj7qcbqsvqukaMCmnwh5BxvI5qee701NvZWV5uxXs/Cl5d/vbh1t4hyWY4Jp91qeneH4zZabGkjjjeDkZrLvtdv747Xm+QfwjoaoLbiY5JLE0ct37zDm5fgVvMqXdzNfymW5YuSe1NSGBcM0PP0rVt9OJAxHz9KsCwfIUD6mndbEKLtdmQFAUrHD+dNMEvVUxjrWs8UaP5a7pJOgC85roNM8CXU0aXetSmyt2+YR/8tWHsO340r2HbmOPstJu9RuFgt7d55WPyqoyTXd6Z8OYNOVbnxJdBWPP2SA/Mf8AePaugs7u20S2NpolmturcM45kf6t/SqkkzSN86ks3bqafvLbRfiHu7LVkk97HFB9jsYEt4BwEQfz9az/ACjO2IlJ559Ku+VHGu+7JX0ANMZ93EQ8uM8YHU0ua/wm0aSS5qj+RWa2giOZPnY/pUTxtOSCS3sDwKvGyDLlxsHYHv8AjR9nVflDY44GP61m9Nep0QUp6WsjP+woG3uSfSpPs6E5DAfjV57VODvAPvVZowpxz1zyOtQ7z1NYQjT6G34Nhh/teHzDkA8iu6uZFSV1QELuO3PWvMrSZ7WQSxybWHI/yK2IvGN3CNtyokA71vC9rnHiYuUuZLQ6PULgQW7zMcYUmvinxxrEviHxTe30rEhpSFz2UdK+pvEfjC0uNDvFQgSNEwUZ74r5Lu9NvLb/AEu5iKrOSU55PNXB2bOKotFYNOsWv7pYM7UHVvQVveI9Cu9JtILnTX8yxlGN69Q3oa0vBGieH7vTrmTW9Se0MhCoyrnmu4g0fQ9H0d7e01mPUYnBJjcYyPoap6O/9feKmk93uclouny+JPCf9meaqvDNvVj6Y5qh4y1eLTorXw7p2HjtVzKxH3mPXNdPpejXclq8/hyL7PEhLzCVx09FzzVGw8G6bfX82oXl1LdKTkxxrjn0yaTtfX+mNJ2Vjzm6t1eEXltGRGThh2U1HaXDW06yIcEGu21/VYLmJ9AsdMFpbR5IQIQcjufX8a4GT5TjnNVByi9dDKcU1pqfUXwv8RHWfDqK7BprU7T6kdq7gzqy5zwR+JrwL4G6u6ahLYs3EqdPpivaRPtJUnOeV9qKqtIqi24W+RoCY9+1Hn56dqo+aenNNMrA4OeKg0LrT4++aTzhjaCetUfOZe/SmtOQpJNFxWsX/NGOOewo80Cs8z443Z/Gm+cODu6ijQEWXmzOFHOATUhlGeprMScNMRu6CnNOc4LCncWvQ0Hmxnnr6U03BHBOO1UPtAHemm53DHFFx2vsXjMW6HHtXP8Ai24I0m4y2B5ZOPwrRafgn2rnfFd4ItMnbgnYTWdR6XRpSXvHhkzHzGLevWmglsZ6dasSshdsJnkmo2ERHC454xSb1LaZH85zu+8en0pY0yeeSR1qURx5AGSR15pPLQ5Kscn9Km47MaxijTG0Fs4z6VEyKxGFqRolYn95yOaQQBRw5yO9NWF8iMtwU2Dn2oiihz80Y9808W7Z3BwQeaesUgIwo3fWgPdZG8MTfKF2n2qE2sY43H35q8trPK25QAo75qtMrpIQFOaE+zDzsReQqKQrkZpRFt7igSSkfcBApTI6jIibJ9admF0tRjQyFdwAx0601bSZ8sOntUwLlt0pxjoBUw3CNjH6daHdE77lDybg5AwO/wBab5cpcLtJxyan3c5c9B2PNIZl6YI+lPUehWKMDkAjBqrcElz+laQZ8Y6juKzLhsyHAxiqiRLXUi6cY5rR0VP3ruT91CazT15Fa+jxkQyuR6DiiWxEfiMyI8jceD15pxkOdqfdHSpSFdBngetNEQLfIdwqfUxaGfMfvd6kSDeQEbOD19atLbJImSCrCnwW8cQDsSOtTzFcnciS2kgJ8zgEelSxxRKocqWDcnjkVIRJxIRlFqOWZFHyjGO2O1TdstNR1LCrbwl2ALrjI+tMe+fyvLUjbVITYYbuFJxkVIsY/eIckdqXKuolJ9Bzzlyn7xsjjBFPWQhuScDnmqoUIdx5A7k81OxYJvUZHXHvTYlJk8cxlDfKcdvrTJYXG2Xfuz69jTkxEu3cc/eyalhOUCz4IbORUt22L0YhJC4BxkYpYYCpBAO7vUwaNDjapweD6CmtOquTUczeiBWvdkwjYkSI/QYOKsWwtxGT827rz2rNWVYg5DHk96e90zKAnWk3LZFRlFPUvXMi54ZgB0IpLeQyDO8LnJ5qi8hXhucihJAAoU5GcHmkm0i1VV9UawupPKZI1+p6Gqct6Uba33s5PvVZ7mQRuy5+gqpJIxBkXIPU1ULvcmc0bMd3GWG92APUYpi6gglMkQOI+ee9ZIumXa7rvGaQ3hQkkgZ7VquYy5ktjojq13cAgnaoGeDjmqTy3En3ctk1QjvmRgjspQjJPWj7cyyBombHuaackNyXU2Y9Gvp1BuF2KTz3OKuwaDbIzEKzrnjcOaZo+riRCLuUkg4ANdLEisgdRnjtVq5d10M+KwQYAjUe2Ktx2KgA7eB7d6tqY9m7IP41najqogzGvGPXuPah2Q+ly+tvEh27QOcc1OkaKMBRk9653TtZLTt9okC7VwAe9Lca7sm86E/LjkdqXMkKOp0gH8Ix+VSZUDkjpXH3viWchkB25A6cZplx4mM0YETfvUXkCh1EtQVmjtEmQ8KR6Zprzxqw2SKzY6DtXCSeIrnylKuy5/L0pItUclQX2l1wCp71Dq22KXK3Y7wzxqFy4yabNcxpIsQcfMuSQeOK46TXZ4IDC3DoMD/9dMsNVmm3tMQ6uenpUe2mlcu0Y6HYR30EknlxtuIGTj0pW1G2QhN68/pXKpfPYq8lvG2QDjjNUI76a6nE8zlVJxjFCrt6iajBpHbpqKSk+XJk+lOiuTIGIbAB6E1zRu937uFChwWBPWnW9/IkgeQfOB1x1FSsVfoNQjfc6jzUQ/MwJPJzUaX9u0vkl9rE4IJ6iuY/tZmkaU8kHHoB7VD/AGjG0jTMwDr09hQ8Q7itHudr9qgRvmPIHr0pZrmOBh5pU5561wH9sOJnbcQuDjmmS65cMT57789Oar2jYRlFanokd7FPGrI4OenNJPdpC/l85HXHpXAWeqLEyuHbjPAPGauf28CzPK3L9cetU6rtoikobtncW1yksIkIC7ucZ5qdTGcEYP0riV1KSdcxqNiYxg89KlfxCsahUkIyNpOOeOlCrJi5bas6+WWONQCSMnH40n2iIMI+SxGfwrhv7dnZBvlyN+QTVmHxBKs6zDDFVx1qvaolHZlN+Cc8880h2ewFcwfEjSmKFpfLDH5j3960G1O0u4vKglKKpweOSKqM+YW2zNCeaFYnZHBYDPB71iy6xHdwEuRCynB4/lWZri3FvD9ot5htPBwRmuON7MXbEhznkZ61Em3sTKfK9jtLTxBsuyJJcJjBPrVTVtTjurjZGAFxjK9656WdiAVQIzDgE9agttQkaXZhdx9ai8mg5lbU6CHUp7KNlZ854AqGe9nYK5fGeMZrJl3SZk8zGDyM1HdXsZIaORyAcYY0JvoHPHl5WjQbU7gOUDu2en1rS0ud7B1n343csp7ZrlTK086+U+3A53HgUQ3EiXW12LZOMim+buZxkoncT65Pclo2UeWBggdc5q3b62xB81BtUZBBrm4HIJjExVWXPNRG9+yWyoX+UN1AzxUKpLodcKa3Zfm1eSS5dyhKNlRz0q9DrsATY5xjua537elxI0qvgA4UN396juLjzGEcxwo9O1VGctmZy5FqmejadBDeKriddrD61cNlj/UJuPtXBaPrs2m4gacPHL6itmDxpd2tzG9sFC4IIK96p1HfQIyh1R2ul+H2u4/tN1epDDnBYn0pdRudJ05vJ0yQSt3kNcLd+Ir6VfL81VQ/MQOBn2qm+u5tRv5KkDOaFJPVs1l7rslY66e8urk/IXfP5VmTOySLDIwVjyec/hWR/wAJHKsaoshXA596yrjU3uJxNuOMc803U7ENJaneW9knlmR3zxnOafM0VuqPHglzgYNcnaa+0cTRMMpjqasLrkkk0Ma4AjbccjABxQpg2raHZi68lFJUDj7tb2jeENb8RJ9rdk0/Tx1nmO0kew6mvNItZjgvBPJIXaNtwY9z7D6V1UvxNvLmxz5obaoUL12+9NSTV0Vd9T0Szs9A8OJ5ekwedcdDdTAFv+AjoKgub0nM8zliTgnOSTXlsHxCuYJP3jLISMY9zTb7x7cXFmsJADhslx1NPnitRWctz0+RoIwJLqUQqxwM/eP0FStJb2iZgAIOA0hFeNah431DUCkrSZ24AOcYHtVaLx5emb7PJOxVnDMSelKLcty3OMI6L5ntRiaRt65YngMRxUsFqYwZPLB9c81wl18SybQLZwbMqF80nv3qjY+P/JjlSWVmEhyxJ+Y/T0qZSbWxcZUoytf5npD3UawNLuAROrAccVD9ogdQ63CDfwPm6/hXjeseNdQkjMUc7rDuIAJGQO1Yj+LrpUSGKZx5bFgd2TmmlcUsTGGlrnust/BFOIPMVmbng9B71Qv9fsLIkGUM47K3NeKnxJeyHe94SzZBHoKda6xKoJkctjoSaH6kxxfVI9ktdXi1CIyxg49c96ZLfxsW2tnHfrXlcPi6a2slsYwBzl3J610en679rtsiUJgYxxzVJWQKsqtlc3L+8iaLY5DduRivNvHpEqwspGFOAB2FdBe3rEMQwx6iuU1r/SoymT06YpqPvJinNuLiyvpNnf6npctrYRPLLGwbaoJOK7Hw/wCFrsQQrrkoDoflhVstj39K47wnqx0rUAXZgjDZIFOMiu5vNGuNHuR4jttQN3ZSxlosElgfQjsa3cmtL2RxwSa0Wp1cGn6fDYXNldOs2rbfMt4Inwuwdm/DtXJa1ruseEJUu7NI1t5vvfIDsbuDXKaR4mvU10XsocMz/Nkdq6KbULvV9Vm0ufTnubaXqAucD1qnGz7oSfMuw3/hZT6vaXUN1pVq5MbDzvLww/GvK7h8uSc9a7HxRHpOiQnTNJkZ2c5lZv4f9muXtbcTSF5Y8qO2TzWa5VqlYG38Mnc7D4SXX2bxHAxbAOR+le8SataB0jmkwWIwR2NfN+nXK6RcpdWsflyJyvNbn/CaanegcBShyfWiTUmmKNoXR9GWxhbBNzH+NXFtlYcMjfRua+e7fx/fqAzMeBggnrWjH8UruJAJM80cum5ftLHuT2Pfy269qrS6eByVYf8AAa8qsvivMzfeYcdjWrbfGCJn8pp8NnGCKOV7BzprU7iWxA6MM5/SoXs5ACF5HY1z8PxWsJsBpImB65FaMfj/AEWXhliP0OKTUuxSlEkgt5MuTnlutK0M4HfipIfEvh9s4XbnrtarC6vokuCLl1z0BwaWqBSVjPZZV6Dio3Ljt15raV9Nk4F6nTuKU2ULfcmhP0NFwSuYLO6nGCAK5rxe7Ppk6jjKnrXfS6WR0VSfZhXn/wASoms9KyAy7nAJ9aiTvY1pqx5M8MmN2D+dNiSTzRtU8HmlMzFss5JoErZwrY96nUv1GTyN5jsVOSfSoQWBydynPerEsi4Dnr9Ki3ljjGSOcU9kDuxm9mxgggU7kcFlyKkDKUGcZ9aYI4geepoTFLWwiOwBHQA9ac8rkgg8e1DLHswRgGo/IJyVbFF7hqkOa4kAOXP4UiSlscbhihYYlzubdx3NA3KSA4Ap6E3fQVgVG4cfyqQK+AxGfbNQlXJ2luM9qk+cD5eh6CjQOoOiD73A9KQ3QdBEkY2nqaRi57E+mOlMKll4Q4HoKNBdRxFuo2rGpz3IqLy48kiTvwKcwYcFWPbpSJFISZGQhF6UId10HPb7Y2cEHA6ViS53n61qSSM3CtkYrLf73aqiTPRDABnrXR6PsisHZh95sfpXOgc9K6G1jZ7KGJMgk5NFTbUmldyMdGTbt28kVetoAqrJKny44zWbaFvMwdwP05rVNwxh2uT7VMlbYyj3B51QFQgUdQQapSXAlyA2MnjmmTFnLBTjPUGkt0RlxINreopKKWom2y0LiQx+U7Zx07VXkSUhRjhh1I6Gnsv905xjAapd5C7eMY/KltsG+5UjjcvhmyVwcdqtKS7ErwBTF2ksQMcUkM2N3GM8U3qGwsgGzByM9aspGERQTwBx9KjUCVQH5I6Y449aVmwwBx04yah3egyWSLLL/dIxSqpCbuhX+dDSbY8g5O6onnJG7OOcH1qdWO6Q5pATk8ZHeq/nYbII96bku27JxVWZiHK9+9aRgS5Fx5c4PrxUodVbdnkcgVU+Uhckcfr7U/eCu0nOKTimBO8xbg0KTCOXUjrxVRnLBti8CmPI5IU9fQ0+TSwrmhJO4jIiwuRSB4wmBk/WoDgplicnr6Co4W3MQozikoIbuWkWQNvjPI/2e1VZkBlU/eGMkdqnWUkkM2BUXlsMkt1ORzzVrRhcrpvPyq4X5sc1MpMbAnt79aGtjIQ+7ao7Dk1YaKIAIo3NjvTbFYWGUt0LFieDnFdHYa5eW5XzJNwAxg1zcNm7fOpAwexq66HA
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
Apr 28, 2011
506
Good idea about the extra mounting although this project is getting way out of hand money wise so dont think i will bother. with regards to using different sikaflex for the cable entry gland can i ask why?? also i notice it looks like there is only 1 cable going into the gland??
good neat job though hopefully mine will look as good.
2,400
johnandrew70 said:
will use a small hole saw on slow speed inside and keep checking there are no wires there, Can you tell me which Sikaflex is the best i have been on there website but they all seem to do the same job.
I have found one of these for the inside of the van to make it nice and neat.
http://www.ebay.co.uk/itm/CABLE-ENTRY-COVER-BLACK-SOLAR-SATELLITE-AERIAL-AIR-CON-WEATHERPROOF-SIDE-WALL-/231105747786?pt=UK_Campervan_Caravan_Accessories&hash=item35cef9db4a
I used Sikaflex 512 to bond the panel bracket (metal in my case) to the roof. It's important to gently rub the areas of roof where the brackets will fit with emery cloth, not down to the bare metal but enough to take the gloss off the paint to provide a key for the bond. After keying in use white spirit on a rag to remove any contaminants followed by methylated spririt to get rid of greasy residue from the white spirit.
If you mark the positions of the brackets you can use masking tape round the edges so that much of the excess will end up on the tape rather than the roof surface. One tube of Sikaflex 512 is more than enough to bond the brackets, bond the the entry gland and to fill the gland and seal the grommit and cable entry hole. Apply good substantial amounts to the beads of Sikaflex, press the brackets down, lift them slightly and press down again to spread the bonding agent. When the brackets are fixed remove the masking tape and clean any excess with white spirit.
It's possible with a bit of forward planning and forethought to make an educated guess as to where any cables will be in the roof. Have a look which side they enter the main roof lighting and the Omnivent if fitted. You need to get from the panel down to the under bed storage near the battery box. On Swift caravans it's possible to wire the solar regulator directly into the charging circuit on the wiring loom using one of These
Plan your cable route for the shortest cable length between the panel and the controller to minimise voltage drop.
On my 2008 Abbey (identical to Swift) I entered via the top of the wardrobe on the offside (drivers side), passed the cable into the overhead lockers ( the one over the sink has a false bottom to acommodate flourescent lighting) from the wardrobe and from there down into the under seat locker close to the battery where I mounted the controller which I connected to the charging circuit.
You'll see the plastic socket for the connector coming off the wiring loom close to the battery charger and battery box in the under seat storage area. Mount the solar controller on something which will provide a cooling / air gap underneath rather than direct to a wall or floor panel because they can become warm. I used some spare plastic furniture screw blocks.
Apr 28, 2011
506
Hi Parksy
thanks for the info. I will be running the cable to the front where the tv aerial is then dropping the cable down into the cupboard where the booster is situated. I was then going to follow the cables down the boxing where the chimney goes as all the other cables seem to take that route (240v also), but decided not to out of precaution, it gets very hot in there so decided to drop it down through A really thin cupboard that houses the accasional table then through the chest that has the truma heater and into the bench where the battery box is, this is where the controller is as I was told this had to be as close to the battery as possible, from the controller I have installed a fuse box then it runs to the battery with leads I have made up myself as there was a lack of solar connection there.
Note, the controller fuse box and cables to the battery are all there as I have been running a 30w panel lashed up in the heki roof light so really it's just a case of putting the panels on the roof and running the cable down, drilling the hole in the roof being the most daunting part of all. I shall use sikaflex and do as you said cleaning the roof with white spirit etc we have pads in work that the body's hop uses for flattening back panels on cars before polishing them so will use one of those instead on emery.
I just have one task left and it's the biggest,, I haven't told the other half I have just spent nearly £200 on the whole lot haha so I could very well be living in the caravan when I tell her, how can I convince her it's going to be worth it?
2,400
I hope that all goes well John. To soften the blow for the other half you could always take her on rallies off ehu where in the lighter months your battery will remain charged with no mains electricity to pay for.
Rallying is a good and inexpensive way to maximise the use of your caravan and you will be able to stay in places not normally open to caravans.
There is no need to pre book on C&CC rallies, just turn up when the rally is open.
Apr 28, 2011
506
Ideal I will look into that although I an not keen on putting the fire bucket in front of the van. If the van catches fire the bucket full of sand or whatever is not going to do a lot,, I suppose if I was still a smoker I could put the dog ends in the bucket haha.
will take photos of the project and put them on here when I do it.
4,152
1,884
If the OH's clothes ever caught fire, so easy with synthetics, that bucket of cold water could make all the difference to her future life.
Apr 28, 2011
506
hahaha that made me chuckle.
Apr 28, 2011
506
will one tube of sikaflex be enough to do 8 mounting feet and a cable entry gland? dont want to get half way through the job and run out
2,400
Yes, one tube should do it easily. Bond the mounting feet first before doing the cable gland.
It might be easier if you attach the panel to the feet, prep the roof surface and mark the positions then turn the assembly over to apply the Sikaflex.
That way you will know for sure that you'll have enough left but there shouldn't be a problem.
The sikaflex has an 'open' time of a few minutes although my advice to carefully work out and mark the position of the panel will lessen the possibility of mistakes.
It can be slid around a few MM if adjustment is really necessary, but assemble the panel and do a 'dry run' first to increase your confidence and lessen the chance of a slip up when bonding the feet to the caravan roof.
It's normal to put a bucket of water in fron of your caravan on rallies, but the bucket doesn't have to be a mega expensive 'Fire Bucket'. Mines an ordinary red bucket fro a pound shop, I use it to wash down the front of the caravan if it's muddy and in summer dogs often use it to drink from so it's no big deal.
Yes i only have one panel
I would second the dry run advice, as the panels are quite long id wished i have someone else the otherside of the van to help position it.
I assembled mine first then stuck it to the roof.
Apr 28, 2011
506
The best thing I ever bought was a multi function ladder that can be turned into a work platform it's high enough to work on the roof of the van, I used an ordinary ladder for years and struggled, now I don't have to worry about coming back down the ladder to move it accross so will make installing the panel a piece of cake. Hopefully haha.
The masking tape idea to mark the position is good.
It wasnt the height that was the issue , i laid my panel across the van , its when i went to place it in the middle of the van and at 1 mt long and quite heavy caused the other end to drop
Apr 28, 2011
506
ahh i see what you mean, i am puting mine on each side of the roof so hopefully will be able to handle it ok, i might get a friend to help position from the mini heki,(just big enough to get your head and 1 arm out
4,152
1,884
In work I have done with marked similarities to this, and requiring great precision, I and those advising me used the following technique:
With the soggy adhesive clad unit we placed it down on battens of wood that held it just off the surface; then moved things in "plan" to be exactly over where it needed to be before easing out the battens one by one. In your case I would use four short battens.
2,400
I mounted my solar panel slightly to the nearside to slightly counter the weight of the leisure battery, fridge, cooker and wardrobe which are all fitted along the offside of my caravan. It wasn't difficult to position it by myself after I'd marked out and masked off the area for the mounts. My panel is mounted on two Z sections of aluminium alloy and a variable adjustable mount fastened to this.
I bought the adjustable mount to allow the panel to be moved through up to 90º to maximise the exposure to light when needed but I have to say that I don't use it very often.
Apr 28, 2011
506
Just wondering if anyone has done a dry run. Marked the roof where the brackets are then removed the brackets from the panel and the stuck them in place without the panel. Not that I would want to try it but curious as to how it worked out. I should think trying to screw the brackets on whirs stuck to the roof could be more of a nightmare than dropping the panel in the wrong place.
The panels are out for delivery today so feeling excited haha (big kid)
2,400
It's much easier with the brackets attached to the panel. It would be difficult to drop the panel into the wrong place unless you were blindfold when ftting it
The position of the panel depends on the positions of the cable entry hole and any rooflights or Omnivent. It's not rocket science and a few millimeters one way or another shouldn't make much difference.
Try to shield the panels from any sunlight when connecting them to the battery, an accidental short circuit can ruin the panel so you don't want the panel to be generating power when connected up.
Apr 28, 2011
506
Panels have arrived all safe and sound, the wife has taken it quite well, she has not kicked me out yet anyway
On a serious note though if anyone was thinking of buying a Solar panel i seriously would consider buying from http://stores.ebay.co.uk/The-Friendly-Green-Store
good comunication and express delivery also gave me a little advice so what more can you ask for.
