Solar Panels
May 14, 2009
30
We have decided to try some rallying with our twin axle van. What size solar panel would I need just to run lights and to charge my daughters lap-top. One of the rallies we intend to go on next year is for 7 days although it is in May/June so we shouldn't need many lights. The others are weekends only. No intention to use anything electric except absolute necessities such as lights and water pump. I have seen one in a suitcase at about £100. Is this big enough for what we want.
Jan 18, 2008
33
Hi Pamela.
Look at detriot solar they will put you on the right path about
solar panels before you buy something that is not up to the job..
3,577
Hello Pamela
It seems that most caravanner's who have experimented with solar panes find that a 60Watt model is enough. However you mention wishing to use a laptop. It is my experience that Lap tops tend to be used for long periods, and as they are usually rated 70 90W, this will use quite a lot of power even when charging.
You may find that you need to consider a 100 or 120W solar panel to cope with all the demands including a laptop.
3,524
1,359
Like Peter T we have a largish solar cell, in our case a free standing one of 85 watts of the crystalline type.
Through most of the year we can be completely self sufficient as the electrical demands other than winter are not that great and the input is generally well up.
However during the winter it becomes much more of a lottery, the demands are up and the yields can be pitifully low. If we have some nice bright sunny winter days we do get exceptionally high yields, most likely as the air is so clean. However on a dull cloudy damp day the cells yield is but a few percent of its rating and if we get a week of these we run out of power.
If your an at all serious camper as opposed to a three day weekender then my advise is to pitch things at more than 40 watts, ideally somewhere near Peter or ourselves at 80/85, then for most of the season you would need to be profligate with power use to be in trouble. If your going to push into the late October to early March use then a free standing large panel is what I suggest you need. Free standing because you are going to have to stand it up at about 50 degrees to catch what little is available and mounting horizontal, as on a van roof will greatly inhibit its yield. Mounting flat on the roof carries very little penalty performance wise other than in those "winter" months, and has some practical advantages.
As I said ours is a free standing one, and that's because of when how we need it to work. To live with such a large panel I made a cassette for it under the back of the van, screwed up into the floor; that works very well.
