HAS ANYONE HAD ANY PROBLEMS GETTING AT THE SPARE WHEEL I HAD A PUNCTURE RECENTLY ON THE NEAR SIDE OF MY STERLING EUROPA 490 AND WHAT A COMPLETE MESS ABOUT TO GET AT THE WHEEL ANY HINTS WOULD BE GRATEFULLY RECIEVED
Chrisbee got to agree with you have never had a problem with my carrier if its greased every 6 months(slides & nuts & bolts) or so (takes about 2 or 3 minutes to come off and do not need to jackup the van Swift charisme 555 to get spare off ) so do not understand some comments about carrier unless mine is different from others (ALKO)works great for me (never used it in anger though and hope never to either )Not fit for purpose? Mine's been carrying my spare wheel since I bought the van, doing exactly what it's designed to do. I service the carrier every year and think it's great for:
a)transporting the spare low down behind the axle
b) freeing space in the gas locker
c) keeping noseweight down
How often do you use the spare in anger?
Ray not fit for purpose why make then then 1,000 sold every yearI have removed my alko carrier, and put the wheel in the bottle box, i did have to use a part of the alko, the bit that secures the wheel, this i screwed to the bulk head to hold the wheel in place.
My locker already had a wheel indent in the plastic floor for a spare, so i put it there.
The down side is extra nose weight, and reduced locker space.
The upside, for anyone who has had a puncture, is a easily accessible spare, that is clean, not rusting away, with the correct pressure.
The ALKO carrier is not fit for purpose. (i love saying that)
Graham yep thats what you pay your breakdown cover forWe had a puncture recently and I changed my wheel with a little plastic card.
It had R.A.C. on it.
Its as easy as that init, cant see what they are all getting worked up about. J.Lo PS 69 years old 9 stone and a bitI've only had to use my spare once, on my previous van. I needed to change the n/s wheel which caused a problem as the spare wheel carrier was too close to the ground to allow me to slide it out. I simply pulled the n/s onto my leveling chocks. If push comes to shove I can use both chocks and some wooden blocks, all of which I carry anyway, to get a lift of at least 12 inches.
