Buffers said:why not get a spare wheel carrier and store it under the chassis close to the axle
Ditto I'm going to do that next week and scrap the carrier, do you know by chance what the ALKO carrier weighs, I can't find it out there, 🙂EH52ARH said:I am about to remove mine from the underfloor carrier and mount it under the bed, it wil be almost exactly in the same place but 18 " higher up.
This is so its easier to change the wheel in case of a puncture.
Try removing the spare from the Alko carrier with a flat tyre on the left hand side, pain in the bum.
Because to slide out the spare wheel carrier on mine involves quite a bit of reaching under the caravan, and I prefer not to do that when it is on a jack - especially the rather rickety one that came with the caravan as standard issue. In fact I now carry two substantial bottle jacks around with me (screw, not hydraulic), together with some heavy timber "squares" that I have found are needed in rehearsing a wheel change at home.chrisn7 said:But why would you try to remove the spare when a tyre is flat? You would have to jack the van high enough to get the flat off and the inflated spare on anyway,t...
Keefanmaxx said:Thanks for the comment Hutch. Mrs Keith and I have spoken about the pro's and cons regarding security of the spare against space under the bed and in the end we've decided to go with the under chassis carrier, which has been ordered for fitting ahead of delivery. I'll take your advice re: trying it at the dealers though .... it's a great idea!!
:cheer: :cheer: :cheer:
