This will work for me. Mine has two outlets. One for TV, other for radio. 12v input. Original has an on/off switch. Never used it.Mine has the built in signal strength finder. I think it works very well. It would be an easy replacement.
This is mine.
The vp4 is the latest amplifier which has a built in signal finder. However i think it was designed for the 570 aerial so i would check compatability.
There is an excellent video on youtube with the Trudgians where he replaces both aerial and amp. It really is a very simple job to do.
Snap we also got signal strength finder in our caravan and it works greatMine has the built in signal strength finder. I think it works very well. It would be an easy replacement.
This is mine.
Thanks Woodentop,I think everyone should read this - too many people don't seem to know.
The earlier Status aerials had the amplifier in the aerial head unit. The box inside the caravan was simply a filter/connection unit to provide power to the head amplifier. In this type of unit the printing on the aerial head was a purple/blue colour.
Later and current units have orange/red writing and the amp is in the box inside the caravan.
Thus the early version of the internal box - which looks very much like that in DustyDog's picture - cannot be replaced with a current VP series unit, but the later unit can. Having said that DD's box has orange writing on it so it should be checked (or confirmed with Vision) which type it is.
Despite all that the early ones were very reliable so it may be worth doing a few checks the simplest of which is to put a voltmeter across the aerial socket on the box and checking for voltage - red (positive) to the centre and black (negative) to the outer - this assumes of course the red LED on the box is lit. If it is not lit then pull out the power plug and check that - again positive in the middle. (It may be necessary to use an unfolded paper clip to get a contact in the centre 'tube' terminal.) If there is no voltage on the aerial connection it should be quite easy for anyone with simple electronics knowledge to repair it. Note also that the aerial on the earlier type does not provide DAB signals, only TV and radio.
Finally a tip for users of the VP series. The radio connection carries exactly the signal as the TV outlets BUT it is not amplified. Ergo if your radio signal is weak move the radio connection to one of the TV outlets.
We have never used either for radio reception. We had the separate aerial, but it worked okay without it being extended. Can't reach the extending aerials on the status, but then never found the need.From memory, the Status aerial with FM extendable rods always had a cheaper version available without the rods - both types were fitted to caravans from various manufacturers , with some manufacturers using the cheaper version with a separate FM aerial mounted on the side wall for radio reception.
Hutch. Missed that one. Yes my Sproket machine let me down! My fault, wrong setting on an old satellite🤬🤬. Works now. Have a few beers for me boys and girls. Great shame we miss this year.Dusty Dog, when at Waterrow, you spen a lot of time sorting out the Sat TV. And it still didn't work, give up and get to the pub first,
Oh sorry your not getting to the Woosie fest, Thinghy Parksy and myself will let you know what the pubs like.
