Has anyone had experience of fixing a stone chipped front window. I have a 1 yr old Lunar Quasar and have a star-burst type stone chip close to the edge of the window (just along the shaded area) which I picked up last weekend on the way to Bath. It's just in from the side where the outer and inner section are bonded together. I don't think it's gone all the way through but can't be certain and am concerned that with the wet weather moisture might get in and then mean a complete new window.
A friend has suggested I use model making solvent and run it into the star-burst to bond the crack. As the stone chip is on the shaded edge it's not an area we look through although I have tested some of my sons glue on an Airfix window and it doesn't discolour it.
My questions are:
i) Is Airfix solvent type glue suitable for bonding the crack?
ii) Would it be weatherproof? I'm guessing that as it's a solvent, the acrylic window should bond to itself so should be okay but would appreciate any thoughts.
iii) Would the solvent work in the cold damp weather we have at the moment?
Any suggestions or thoughts are much appreciated. As the excess on the insurance is £200 if the glue or any other suggestion doesn't work it'll be a new window at my cost.
With thanks,
Gareth
My questions are:
With thanks,
Gareth
