Super Pitch
I'm just wondering about these super pitches. I've been told that all you have to do is put a Ball **** in the water container and hey presto your ready to go. The thing is I use a 40 Litre water container and the only place to put this Ball **** is through the top, but thats where my water pump goes in and I was wondering if it will fit into the same hole. Can some one who uses this method please give me some tips, Thank You.
Hi Paul, I use this system with my 40ltr Aquaroll which has 2 filler caps. 1 on the top & another halfway up the side, where I screw in the ball valve complete with the hose attachment which in turn feeds from the site tap. A good system because you always have water in your container even if there is reduced pressure from the tap or indeed no water at all if for any reason the site warden has to turn it off. Hope this helps.
