Swift Challenger 530 SE 1997, tyre pressure
Hi, I have just got back into caravanning after a 3 year break, recently purchased the above caravan, but with no technical manual etc, could any one advise on tyre pressure please?
Thanks.
Regards Paul.
If you have a look on the following link, it will explain how to read the information on the tyre side walls & how to tell there age, also you will be able to work out what pressure you require...
tyresafe
Be careful,I have come across correct tyres which were rated at a lower pressure (44psi) than the original tyres fitted to the caravan which were max 63psi,and the handbook recommending 54psi.
Check with handbook/manufacturer for correct pressure then check tyres max pressure.
