swift challenger 570 2009
Nov 7, 2008
32
hello to all
can any body help me with the adjustment of my caravan clock the one in the centre console.i cant see how it comes out,cant get at the back nothing in manual
thanks in advance
tony
Nov 7, 2006
136
We have the challenger 530 08 model. My hubby took ours out and he says very gently ease the whole clock and surround out in one piece. He used a very small flat headed screw driver and gently, very very gently ease the screw driver under the surround until it came out. He stresses do this very gently though.
Nov 13, 2007
480
Hi Tony,
You should be able to get access from behind the clock to remove it. If you open the locker door next to the clock there is an access panel which you can put your hand into and push the clock out from its mounting through a finger hole on the plastic moulded panel, if that makes sense.
The clocks have a rubber gator that grips to the plastic panel, the clock can be pushed forward from behind,
Andy
