Swift challenger weight
May 11, 2006
Hello there,
This is my first post on the forums, I initially joined to find out the answer to my following question. However, upon browsing these forums I shall be keeping myself up to date frequently on here.
Question: I am looking at buying a Swift Challenger, the only details I have is as follows.
Year: 1990
Make: Swift
Model: Challenger
Birth: 5
Can anyone tell me the weight of the van, before i travel about 60 miles to view this van i would like to ensure its within my towing restrictions.
Mark
Mark,
Contact the seller - the information you require should be stamped on a plate on the side of the 'van somewhere below door level or near the wheel arch. Or contact Swift customer relations themselves.
Hi mark
I have a challenger and will have to pop out to check it tyres for next week end and will look in my book which is in it. Which challenger are you thinking of getting
john the painter
Nov 2, 2005
1,481
19,185
We have a challenger to book is in the van.
but weights are different for models I will checks ours for you.
Nov 2, 2005
1,481
19,185
I'm back. I have the book.
450/5 490/5 490/5L
shipping length 5.93m 6.49 6.49m
max ext height 2.51 2.51 2.51m
MLW 1050kg 1150kg 1150kg
del weight +/- 5% 820kg 895kg 930kg
tyre pressure 42psi 42psi 42psi
Does this help any.
ground awning channel size 8.47m
Nov 2, 2005
1,481
19,185
.........................450/5.......... 490/5...... 490/5L
shipping length......... 5.93m............6.49.......6.49m
max ext height...........2.51.............2.51.......2.51m
MLW......................1050kg...........1150kg.....1150kg
del weight +/- 5%........820kg............895kg......930kg
tyre pressure............42psi............42psi......42psi
Have had to put dots in as it went gobbledy guk when I submitted it.
