- Mar 14, 2005
- 1,517
- 478
- 19,935
When we finished last Autumn the bolt that holds the sliding bathroom door in place when moving had worked loose. Today I finally got round to looking at it, and typical Swift it was far more complicated than I originally thought. The bolt is held in place by 2 small screws, but to get at them you need to remove the sliding door from its runner,then unscrew the part of the bolt that sticks out. Then the bolt part can be removed and the screws can be tightened, then reassembly is the reverse.
As the bolt is reasonably small I cannot understand wht they could not have fitted one with screws that showed but it is done now.
