A note of caution.
Swift caravans are supplied with two door lock keys. The first is flipper style and it is safe to leave the key in the lock and clip the door open because there is sufficient clearance between the door and the side of the caravan.
The second key is not flipper style and there is insufficient space between the door and the side of the caravan. If you leave the key in the lock and clip the door open you will dent the side of the caravan.
