Swivel Thetford cassette toilet
Aug 21, 2006
13
Hi just put water in toilet after winter pumped the flush a dozen times. The pressure of the flush does not seem very strong,the caravan is only 3 years old is this normal?
Feb 14, 2012
40
Hi
Just a thought.....How much water have you put in the flush? I had until last week, a 5 year old van and unless the water level in the flush was fairly high, the pressure on the flush was impaired.
Hope that helps.
Aug 25, 2010
167
could be the pipes are gunged up with the black stuff that forms when Thetford pink is left in system for any length of time. Have you checked that the flush water is not leaking out elsewhere?
Aug 21, 2006
13
Just been away with van and ended up striping toilet
Then found the clip on the bottom of the pump had broken off
Part number 23845 around £6.50
Seems a common fault!!
Does any one no where to get small amount of PTi sealant?
