Taps out of sync!
Sep 2, 2020
15
Please help
I recently purchased a fold away caravan, the problem I have is, in the kitchen I open the cold tap and it will not run, if I also open the cold tap in the toilet, both taps run but the toilet tap can run also on it's own
Now this is a big ALSO...
If I open the hot tap in the toilet, this will not run, however, if I open the hot tap in the kitchen, both taps will run, also the hot tap will run on it's own in the kitchen
12 volt system
Any help on a solution would be greatly appreciated
2,786
My guess is you have a system in which each tap ha a built in micro switch and any of them can turn the pump on. But some of your switches have failed. Look on YouTube to find how to put new switches in.
Reactions: DaveA1 and RogerL
Sep 2, 2020
15
Roger that John, I will check in am, thanks
Jan 19, 2002
1,711
551
Easy to determine if it is a microswitch system as the two wires from underneath the tap will be connected, and also you can hear a mild click when the tap is operated, which if the switches are in order, should be switching on the pump while opening the tap to allow flow.
Reactions: boundher
Sep 2, 2020
15
My wife is not quiet enough for me to hear mild click...
Reactions: Jcloughie
