If I'm on a caravan site with mains hook up can I still use a normal TV? How does it work eg: watts etc..I know it sounds daft but if I have to buy a low watt toaster and kettle what about the TV??
FOR HEAVEN'S SAKE - there is NO SUCH THING as a DIGITAL aerial. They are all the same, albeit you will need one of the wideband variety to make sure you can receive channels wherever you go.You don't say where you are from or going to Alex but we have switched over to digital in the North West Granada area so you will need a digital aerial to receive a picture.
What is the 'FOR HEAVENS SAKE' comment for Woody!!!??FOR HEAVEN'S SAKE - there is NO SUCH THING as a DIGITAL aerial. They are all the same, albeit you will need one of the wideband variety to make sure you can receive channels wherever you go.
At the moment Border, Granada, Wales, and the south west, along with some of the northern Scottish islands have been digitalified. If your TV does not have Freeview built in then you will need a set top box to go with it.
If you want certainty of TV reception pretty well wherever you are consider getting satellite. It is not expensive and once you've done it a couple of times it's a doddle to set up. For the whole of the UK get a 60cm dish minimum.
Per the other comment, I have been on sites in Europe which are limited to 3A!!!
Thanks everyone...the caravan has an aerial on the roof (i think, it looks like a frisbee) do i still need another aerial? If so what should I go for and where from?What is the 'FOR HEAVENS SAKE' comment for Woody!!!??
