The AL-KO Comfort Kit.
Aug 30, 2006
146
Hello Folks.
Does anyone have information about the AL-KO Comfort Kit which enables corner steadies to be wound up and down from a standing position please?
I would be particularly pleased to learn the length of the plastic tubes involved as the front steadies on our van are set at an angle which requires the corner steady brace to be lined up from the corner of the van.
This has the effect of making the distance from the corner steady nut to the corner of the van quite a bit longer than is usual and I fear that the tubes may not be long enough.
Thank you in hope of an answer.
Olly.
PS - If you don't know what the Comfort Kit is, take a look at .
http://217.199.167.226/pdfs/HSC500winch.PDF
I fitted something similar to the rear corner steadies of my Lunar Clubman using appropriate width rigid plastic pipe and tube brackets bouight from a well known DIY store. Time to fit 30 mins, cost lesss than a
Aug 30, 2006
146
Hi Clubman.
As AL-KO haven't bothered to reply to a query pertaining to their kit, I shall do it your way. Thanks for the suggestion,
Olly.
