Thetford locking filler door seal
Aug 7, 2017
65
Now that i have repaired all the damage area behind the toilet from a possible leaking seal combined with the filler door not properly sealed from the outside, how many seals are suppose to be there, I have one as you can see but there are 3 grooves, extra seals ?? cant find any pictures to confirm how many seals on this part.
Do caravaners empty the chemicals in the toilet while towing or rely on the seals to do its job.
many thanks
Apr 19, 2017
361
I would say that 1 seal is perfectly adequate in the application, and the other rings essentially provide a degree of mechanical alignment. What do others think?
I always empty the toilet cassette if somewhat full, but am not obsessive if there is a little in it when we leave a site. The flush tank I like to see less than half full, but again am not obsessive.
Apr 20, 2009
5,638
1,039
many thanks
NO I empty mine before we leave site :lol: :lol: :lol:
just think of the consequences of the contents on blow back :lol: :lol: :lol:
1,819
The recommendation is to empty it to stop water moving when traveling and causing instability, but they contain so little I do not bother and have never had a problem and ours is at the extreme rear corner. A near full toilet might be another matter though.
4,568
On travelling , We keep about 1/3 from empty. Just incase we need to flush when stopped.
Sep 29, 2016
1,829
245
All things considered (well almost :unsure: ) good practice I agree, I admit I do not measure 1/3rd accurately by any means :blush: .
It is handy to keep a little bit of everything in reserve for contingencies ;)
Aug 7, 2017
65
Well for the sake of £2 i've added another seal but will probably empty it while towing as i've seen first hand what damage it can cause from the last owner.
Apr 19, 2017
361
welshti said:
Well for the sake of £2 i've added another seal.
You buy expensive 'o' - rings! Keep a look out in Aldi/Lidl for the selection boxes they have from time to time. (Ideally get a metric box and an Imperial).
Aug 7, 2017
65
did search for ages online and being 75mm od 65mm id x 5mm it was hard to find any locally lol..
Jun 11, 2012
1,533
33
19,685
Hi Welshti I have just experienced exactly the same thing thing. Damp in the toilet but thankfully one area being very small. Engineer found it on the service.I suggest do like I did engineers recommendation while you have it stripped down put two seals in . I had problems tracking the seals Thetford dont sell them you have to but the complete fill tube (Robbing Sods ) I did find some one to supply them in the end ,cost me two quid for the two. Hope this helps. Sir Roger
Aug 7, 2017
65
It was one of the first things I noticed after buying my first caravan and getting it home
( 2008 Elddis Odyssey , it must have been leaking from the door seal and o'ring for some time as the batterns were rotten and pictures in my other topic show the extent of the damage but its all been repaired now and I also put 2 back o'rings on it. I will also be emptying the flush before any towing.
Jun 11, 2012
1,533
33
19,685
Also another recommendation is not to fill the the flush tank to the top just add the require amount ..
Sir Roger .
