Thetford n100
May 15, 2014
26
My led fridge display has no power to it circuit board looks like new had a test done on it told it was ok also I have been told to replace fuse on board but there is not one so any help appreciated
Oct 3, 2013
890
90
18,935
I take you have checked the electrical supply is present at the board.
Is the LED display an integral part of the board or is it separate - if separate could be LED failure
May 15, 2014
26
Yes seperate got a block connector with about 8 wires going into it so not sure which is power lead also nothing to go by but got board out and it looks ok
Nov 6, 2006
731
Is the light on in the fridge? If not, suggests no supply at all to fridge, not just the board.
I would expect there to be a fuse in the main 12v fusebox, probably a red 10 amp - check there first.
May 15, 2014
26
Checked all fuse and all ok checked it with a voltimeter ....and yes nolight on in fridge and no power what so ever to lcd board any help as always appreciated
