Thetford N122 Fridge
Mar 31, 2010
16
Hi All. My fridge, which was working fine on mains voltage has now stopped getting cold. All appears well, the blue power light is on, the LCD is showing no faults and there is heat coming from the outside vent but even turned up to max there is no cooling. The door is shutting ok. Please can anyone help?
Apr 7, 2008
4,909
How long as it been on ?
I thought i had a problem last weekend, but by next norning it was -15c in the freezer box & 2c in the fridge....
Have you tried putting a bag of frozen veg in to help it a bit ?
Jun 17, 2011
826
27
Have you tried it on gas? If heat is coming out then the heater must be working. My only thought is that you have some how lost the refrigerant. If you get the same on gas it has got to be that.
Mar 31, 2010
16
It had been fine for a few days but then we noticed it seemed to be warm. Had no access to frozen veg I am afraid (if only).
4,225
Hello James,
Is you caravan pitched level? Some fridges wont work uless they are virtually on the level.
Other things that can upset them, if the caravan has been towed over rough ground , they sometimes need an hour or two to settle themselves out berfore being turned on.
If neither the above applies, then trying it on gas may show whether the refrigerant circuit is faulty.
Mar 31, 2010
16
Van has been on site and level for a week and fridge appeared to be ok. Will try on gas next weekend and see what happens. Thanks.
Mar 31, 2010
16
I have just read an article which had a link from this Forum some time ago, which relates to the same sort of problem. Apparently this type of fridge had an electronic board problem which was replaced under warranty. This was on 2007/8 models and mine is a 2007 van. I think a call to Thetford may be a good idea!!
Mar 31, 2010
16
