The toilet in my 2009 Lunar Delta is a pot one and the seat slides all over the place.Has anyone else got the same problem and if so have you fixed it as i cant cure it .
Im holding tight Kev . here's a good one ,even the Thetford engineer admit its a design fault and they are trying to fix it, another **** up.Gagakev said:Fix hand rails to the van and hold on tight![]()
Could'nt resist that one, I know your problem though, I have the same problem with our ensuite at home so use the main bathroom.
And no, I havent found a solution yet.
So good luck on your endevours
Kev
