Toilet Fluids
Hi Everyone,
I just wondered if someone would tell me please what is the difference beetween Blue toilet fluid and the green one because quiet frankly I Can't tell the diffence other than the colour.Jim
Sep 26, 2006
153
I had heard that you can put the green one down an ordinary toilet to empty it, whereas the blue on is purely for chemical toilet disposal units.
Aug 24, 2007
139
There are certain Caravan Club Sites that you are not allowed to use Green fluid. It is something to do with the environment. Ken
G
Guest
I believe it used to be the case that the blue fluid was formaldehyde based, but that may have changed. The green was supposed to be non formaldehyde, but probably was just as harmful in a different way.
Having worked in the North Sea you could look at pollution in 2 different ways. A heavily toxic chemical that only lasted a very short while before disappearing, or a milder one which took much longer to be effective, and therefore was hazardous longer.
Some of the so called 'green' chemicals are found to be even more nasty than the ones they are supposed to replace.
