Tow ball coatings
Sep 18, 2012
15
I have just got a new car (Touareg) with a factory fitted tow bar. This seems to have a painted finish. I know all coatings should generally be removed from tow balls but this is a very hard and seemingly thin finish which would have been electrostatically applied and I am wondering whether to remove it or not.
Any thoughts gratefully received!
Iain
Jun 24, 2005
704
Hi, yes you do. This will be a very smooth coating and the Alko (or similar) stabiliser needs a rougher finish to work properly.
936
Yes, the coating must be removed or it will contaminate the friction pads in the hitch stabiliser.
Also, it MUST be an extended neck towball to allow correct movement of the hitch around the ball.
If you have the standard short neck towball, it will cause severe damage to the hitch.
Apr 27, 2015
128
I used a wire wheel attachment on my drill and it was still hard going getting all the paint off!
