hi I am thinking of trading in my caravan, and the one's I have been looking at have the ALKO HITCHLOCK dose this meen that I have to change my tow ball on my car.
Kind regards
Mick
Kind regards
Mick
Cheers Julian.Hi Michael, if you get a van with the Alko hitch you will need to change your towball to the Alko extended neck ball. The Alko hitch will foul a standard ball when it pivots and turns.
SORRY... Existing ball ....Michael. You can just fit a 1/2 inch spacer behind your existion ball if you want to save the cost of a new ball.
david, You can get a tow bar from loads of different places e.g. towsure.com. i'll be amazed if you can't get a detachable one for your car. but surely the bottom part of you tailgate would be well above tow ball hight when dropped flat?
I'd be supprised if he's got a 2 inch ball.Hi I think Julian is referring to the old "imperial" towball.
I have a detachable swan neck towball fitted onto my 4x4 which is fine for my Bailey. As long as the towball is the modern EU Standard 50mm then you will not have a problem.
Easy solution, seeing your towbar is "detachable" is to take it along to the dealer and hitch it into the Senator. Puts your mind at rest?
Good point, But i had a spacer kiking about & mu bolts were long enough.Gareth,
Why bother? By the time he's bought a spacer and two new extended high tensile steel nuts and bolts he may just as well buy the real thing.If they are buying new caravans the new Al-ko towball is normally provided FOC or if it's second hand from a dealer they should get the dealer to throw in the new tow ball foc.
Cheers
Dustydog
