towball not sure!!!!!!
Jul 24, 2008
41
i have a standard towball fitted on my vauxhall zafira which i used to pull a trailer tent, is this ok to pull a caravan with?
if caravan has alko lock do i need a different towbar fitted?
Jan 28, 2008
194
C,
Provided that you tow bar is the correct towbar for your vehicle and your vehicle is heavy enough to tow the 'Van you are getting then you should not have to change anything. UNLESS your new'van has an al-ko stabiliser hitch which may require an extended neck towball (which should cost no more than
