towing with a citroen c5 2.0ltr 110hp estate
May 12, 2005
470
daren,
It all depends what you are towing, IE a mini will handle the average trailer for trips to the tip.
If you tell what you wish to tow with kerb weights etc I`m sure someone will advise you.
Tony A.
Oct 10, 2008
daren,
Tony A.
i believe the kerb weight for a citroen c5 is 1438kg.i was just enquiring as to whether they are good tow cars in general?
Oct 10, 2008
daren,
Tony A.
Mar 23, 2008
132
Hi I have a Peugeot 406 with this engine and tow a caravan that weighs 1400kg and it tows it fine. On the motorway I can use fifth gear most of the time even on inclines I feel there is always enough power and have towed all over Britian with it with no problems. So your car should be fine.
