Beehpee said:
A tracker has 2 batteries, one is 12 volts and is kept charged by the caravans leisure battery, this battery powers the alarm which is part of the tracker system and also the tracker itself, there is also a 6 volt non chargeable battery which will power the tracker in the event of the leisure battery going flat followed by the trackers own 12 volt battery, the 6 volt battery will last for years so long as the leisure battery is kept charged, if the leisure battery go's flat and the tracker 12 volt battery does the same as a consequence of this the 6 volt battery will go flat probably within a week, if the leisure battery is charged before the tracker 12 volt battery is flat it will then recharge and the 6 volt will not have been discharged at all, a tracker current draw is 2 milliamps so on its own a tracker would take ages to flatten the leisure battery, both the 12 & 6 volt tracker batteries can be replaced although its highly unlikely the 12 volt will need changing as putting th caravan on EHU will soon restore it to fully charged.
BP
The above is incorrect as Tracking units are stand alone units and are hidden somewhere in the van,some have a 12v supply, but its not to charge and when this is lost it reverts to its internal battery which has a 3 year life.Its the alarm that has a separate 12v rechargeable battery.
If they are integrated then all it is is a sensing wire coming from the alarm output to the tracker unit, but most tracking units have an internal movement sensor and are armed separately from the alarm and activated by calling a help desk.
Some technical bits from Tracker
Battery Backup
Your TRACKER unit is fitted with
a non-rechargeable back up
battery. This design feature allows
the unit to continue to operate
even if the main vehicle battery is
disconnected, which maximises the
security of the product. This feature
now allows the unit to operate
unassisted for up to one month.
However, it must be recognised
that the unit will draw power
from this back up battery
whenever the main supply is
disconnected, for example, under
theft conditions or during a
vehicle service.
The back up battery life will be
reduced by the duration of the
supply disconnection.
Therefore, could you please ensure
that your vehicle battery is always
kept charged. Whenever you have
work done on your vehicle, you
should advise the dealer that if
battery disconnection is required,
then this time should be kept to a
minimum. Remember, the unit will
work indefinitely when the main
vehicle supply is present.
