johnwillypat said:
hi i wonder if anyone has changed the element on the above
Yes! I had to change mine when I was in Spain over the winter last year. I got a company to send me the element by post. As others have said, it should be possible to get the heater to reset itself once it cools down, which it will do by the time it's filled with cold water. However, it's my belief that you can do so a limited number of times before it burns out. If it comes to changing the element it's comparatively easy. First find out what wattage yours is. Some of the fibre board covering will have to be cut away. With the boiler empty, disconnect the wiring, undo the two small nuts at the end of the element, and the element will withdraw from the boiler case. If the boiler is close to fittings or walls, the element will need to be manoeuvred a bit to withdraw it. Use a new gasket when refitting.
