Truma 3004 heater
Mar 12, 2015
Hi,
There is no spark on space heater had anyone have any ideas how to check without haven't to go to dealer
4,335
Helo Voldolan
The fact you have had to ask the question suggests you are not adequately familiar with gas appliances, which means there is not a great deal you can do to effect repairs without involving a trained fitter.
However if you have a look at this thread
http://www.practicalcaravan.com/forum/technical/50725-trumavent-heating
You will see some hint on how to check the ignitor. But beyond that I have to recommend you refer it to a dealer.
937
ProfJohnL said:
Helo Voldolan
Hang on a minute, the OP asked for a possible reason why his fire was not sparking, which on Truma fires is almost always due to the igniter battery being flat, usually because the fire has not been serviced for a good time, or the owner has not switched the control knob off properly.
There is certainly no need for a trained fitter to replace the battery as it does not even involve removing the fire front to do, it is accessable from under the front left hand side of the fire and is a simple slide up panel and replace the AA battery.
If the fire THEN does not light, it is time to involve an engineer , if needed.
4,335
Hello Damian,
Thats what I actually tell the OP to do, but rather than retype the whole posting in the other thread I pointed to it.
Which first checks the batteries then how to check if the ignitor is actually working.
Mar 12, 2015
hi, Thanks for the ideas the battery was flat but also a connection on the side of battery was hanging off. All is well.
