Truma Crystal Water Pump
Apr 20, 2009
5,563
938
Looking for a spare pump for the van, went to dealers and there's was a staggering £16.00 more expensive than online :(
Now my question is will the new mark 2 version fit mine, will post photo of existing one and the Mark 2 version
thats the existing one.
And thats the newer version, (cant find the same as mine) it's a
CARAVAN TRUMA CARVER CRYSTAL 2 HI FLOW WATER PUMP EP1622's
The connection's look the same but the body has by the look of it exrta cut out's
Anyone help please.
Apr 7, 2008
4,909
I would give them a ring because not having your old one and a new one side by side to check for any differences it's hard to say ...
Apr 20, 2009
5,563
938
Gabsgrandad said:
Kev, -- Got one here complete you can have.I'll roll it up and send it to you.
Youre a smashing bloke really (dont look at the woosie thread reply I replied to earlier!!!).
Oh just had a email alert ,......must be your good self Sir ;)
4,269
You can always rely on the Woosies :p :) :cheer:
By the time the next Woosiefest comes round we will have rebuilt most of Kev's Fleetwood :silly: :kiss:
Well done Sir Gabs
Apr 20, 2009
5,563
938
Well done Sir Gabs
Tis only for a spare Dusty, but you know my luck things just go wrong all the time :(
Why do I keep doing this caravaning lark??? :woohoo: :)
4,269
Well done Sir Gabs
Because you are a Woosie :evil:
3,595
Apart from the obvious impediment of being a Woosie :(
You dont have to continue to use a Truma Pump. By carefully removing the pump from the hose, you could fit almost any other make of submersible pump. If you decide to do this one tip is to unscrew the wires from the plug, and tie a meter length of string to the bare end of the wires. Then as you pull the old wire out it pulls teh string through which you can then use to pull the new wire back through. :silly:
