I have a 2004 Bailey Pageant Moselle fitted with a Truma S3002 heater with Truma Ultraheat I purchased the van secondhand having owned a Ranger from new before with a Carver system fitted. My problem is I'm not sure if the heater is operating properly as I cannot understand the operation manual as it seems to cover so many different heater types, I have set everthing as descibed, the heating works but the fan only runs at a steady speed while in the auto setting i.e three way slider switch on top of heater set A or to the right hand posistion & the fan dial set too number 2 as in the Bailey manual( these controls are on the top left of the heater) i understand it to say that the fan speed should adjust automatically to the heat output I also beleive that our caravan also has a remote heat sensor fitted near the front roof lockers. By turning the fan speed dial the fan does speed up & slow down.
Am I getting conffused with the carver system of my old caravan which would blast out hot air then slow down when temp reached? any help greatfully accepted.
