Having problem with pump switching on & off , it’s not pump I think smart switch seems working ok, could fault be in truma ultra flow housing nrv, if so could I insert inline nrv ,David
No just the smartswitchDo you have an in-line pressure switch that needs adjustment - helpful videos on YouTube if you google it?
Hi David, There is no NRV in the housing, . It should be further up the system. Which caravan do you have.Having problem with pump switching on & off , it’s not pump I think smart switch seems working ok, could fault be in truma ultra flow housing nrv, if so could I insert inline nrv ,David
Thank you most helpfulSimple answer is yes if you fit it in, but it will need to be on the pump side of the pressure switch to lock the pressure in the system.
no leaks ,there must be something in housing to keep pressure in cold water feed as there is nothing in flexible pump hose & pump. Ie it seems to get pressure up switch off release pressure & start up all the timeHave you check both drain valves, and also the seals on your pump connection to the caravan. It sounds like a slow leak somewhere.
