The last two years our caravan was serviced the engineer had problems with the gas lighting on the water. It was at the end of the winter and blamed condensation using a hairdryer on the PCB board- it lit then. This year as we are going away before we can get it serviced we tested all the kit ourselves - same problem. We heated the water up on electric and then the gas worked ok, so seemed like the same problem, But where we are going doesn't have hookup - how can we cure this ? I've googled a replacement board and they are expensive !!!!
Thanks for any suggestions
