truma ultrastore water heater
another query while im here! the does anyone know if the truma ultrastore water heater switch in the psu heats water without using the control in the caravan (the one showing gas with the green led) while plugged in to 240 in an abbey vogue 540 2008 model
Gareth,
The switch marked water heater on the PSU controls the mains electric element in the water heater.
The one showing gas in the body of the caravan just controls the gas water heating and does not need to be used when using the water heater on mains only. When useing the water heater on gas you can control the water temperature by turning the dial. When on mains electric the temperature is fixed.
You should have received a handbook with your caravan which explains the use of the water heater.Also your dealer should have gone through the operation of the water heater when he did the handover of the caravan. Sadly some dealers do not do a complete handover.My dealer Golden Castle does.
Hamer
