PaulT said:No, I'm plugging it into the output of the Sky box as stated above " I've tried the filter in both the outlets on the sky box."
There is nothing on the packing of the 4G filter to say it's for Freeview only but I bow to your greater knowledge Woodentop but this leads me to ask - what can I do to stop this interference?
KeefySher said:PaulT said:No, I'm plugging it into the output of the Sky box as stated above " I've tried the filter in both the outlets on the sky box."
Switch your phone off? You are on holiday, oh hang on, leave the TV at home too??
PaulT said:If I can explain my set up someone might be able to help. y box.
Something else which might be relevant - the Sky box is connectef to the aerial socket on the TV (i.e not via a Scart lead).
Anyone got any ideas?
Woodentop said:Just had a look at the original post. Signal coming and going suggests to me that the tuner is wandering OR the signal being put out by the Sky boxes is not compliant with what the TV expects. In the old days one tuner memory on analogue TVs was specifically highlighted as for video input - it was usually the highest channel number. You could try that.
It is unlikely that 4G interference will be the issue BUT you can get round it. Get into the Sky box engineers pages (on a Sky+HD box it is Services-001-select (sometimes 401) without pauses) and change the RF2 output channel to something below 50 or for that matter down in the 20's if it will take it. That will put you several 100MHz away from 4G.
