- Mar 11, 2008
- 7
- 0
- 0
I have a fairly new, standard flat screen LCD colour TV & digibox if needed. Can I receive TV reception in France with this set up ? If not then why not ?
Thanks Barry
Thanks Barry
Unless you speak French, getting TV reception in France will not be a lot of good for you!You might be OK - my cheapo 10 inch telly bought on ebay supports SECAM as well as PAL, have a look in the settings menu.
Pete
Sky is not needed but a digibox of some description is.Barry,
The answer to your question is yes & no, but your question really needs qualifying, by TV reception in France one assumes you mean UK tv? if so it would be highly unlikely you'd get a digital signal as south UK (Kent, Sussex & Hampshire,the nearest counties to France)we're not set to go digital untill 2012 & what digital signal we can get is very, very weak! it's possible that you might or could get an anologue uk signal in Brittany & some parts of Normandy, you'd need a really good high gain aerial set quite high up, but the odds are the French TV signal will "bleed" over the UK signal giving you ghosting & a picture thats almost impossible to watch.
The only sure fire way of getting UK tv in France is to go satelite, that is Sky digibox + freesat card & a satelite dish set up.
Hope that clears up your question?
GeorgeB
