TV Size help - 2020 Bailey Pegasus Grande Brindisi
Aug 11, 2024
Hi folks, any other Bailey Pegasus Grande Brindisi owners here who could advise what size TV can sit on the shelf area above the fridge (don’t really want to wall mount). Many thanks IMG_9354.jpeg
Oct 19, 2023
639
510
2,135
I think that you'd be better off using a tape measure than asking for advice in this instance. TV size is the diagonal measurement of the screen, but the stand and screen bezel could make the difference between it fitting or not. One 24 inch TV might fit but a different make (or even model) might be too tall.
You’re right, this is just along shot, I did roughly measure the diagonal (only had limited access to the caravan at the time) but just thought I’d check on here in case anyone else had a free standing tv there and I would have asked for make/model etc
Feb 13, 2024
1,578
1,011
2,935
I have mine sitting there but had to take the stand off it, it's a Panasonic, don't know size as I'm away in it.
Feb 13, 2024
1,578
1,011
2,935
Should have said van is lunar venus, and the TV was not caravan specific, just a old one I found up my loft.
2,373
As I have zero visualisation abilities, I would end up cutting a big bit of cardboard to the same dimensions as a likely TV, adding a bit for a base and putting it on the surface to see how it fitted.
You may not need to faff about quite as much.
Mel, That’s actually a good idea, appreciate your help
Oct 19, 2023
639
510
2,135
Once you have the max height and width measurements of the opening you can check the size of TVs on Web sites like Currys. They give dimensions including stand and bezel.
