tv through lap top
Jan 14, 2008
8
can any one help I have a dvb-usb2.0tv stick which I run through my lap top to pick up digital tv it runs ok for 30-50 sec then the picture pauses then carries on and so on and so on
Jan 28, 2008
129
Alan, it sounds like one of the following:
1) the signal is not strong enough, and drops out occasionally.
2) Your laptop either has some other process running which intermittently demands most of the available processing power, causing the DTV application to pause (Windows itself most likely)
Without seeing the problem, it could be either of the above. Does the problem go away if you are in a strong signal area? Your DTV application should tell you the current signal strength and signal to noise ratio. Are you using the caravan aerial and booster? If so, then on many sites you may need a better aerial.
Hope that helps a bit.
Cheers
David
