Twin Axle Nose Weight
Hello again, This is probably a silly question but I need to ask(newbie, 1st caravan). I have a twin axle caravan. How do I get the nose weight correct as the caravan sits flat with being on 4 wheels? Can I still measure the nose weight the same as I would a single axle? Do I just put the gauge under the hitch and raise the jockey wheel and legs? Thank you. Niki
Niki,
The way you have described checking the Noseweight is the correct method, but chock the wheels to restict movement.
It's the equipment in the front locker that will determine the noseweight of an empty van, although some vans will have some noseweight from manufacture,
best regards, Martin
