Twin axle pros and cons?
Sep 2, 2023
122
89
1,635
So, we've decided to upgrade our 2018 Swift Challenger 480 (2 berth) and are searching for a suitable 4 berth. We will be towing it with our 2019, 240bhp Volvo XC60 T5 (petrol) Inscription. Many of the caravans we are now looking at are twin axles. Having never towed with a twin I could do with some background info regading pros and cons. Apart from the obvious advantage that heavier vans are more stable with 4 wheels than 2 and the disadvantage that 4 tyres are more expensive to replace than 2 is there anything else to be considered? I'm sure there is. For example do it need 4 motor movers or will one either side suffice? Any tips gratefully received.
921
The chassis of a caravan with two axles obviously weighs more than one with a single axle, thus increasing the MIRO and consequently reducing the payload potential within a particular MTPLM constraint.
A twin axle is less manoeuvrable than a single axle and tends to churn the grass up more when pitching. For this reason, some campsites, particularly on the Continent, won't allow them.
Reactions: JTQ
There are plenty of SA available that have greater weights than a TA. Adria for example.
I’ve had both.
But you must ensure whatever you choose
Your car is capable of handling the MTPLM
You fully understand setting up, the weight balance within the caravan itself.
Ok , assuming all correctly loaded.,so I’ve had both. No question the TA is more stable, less prone to being affected bysevere crosswinds.
A quad drive MM is an over kill imo. We have a simple Powrtouch single fitted on the front axle.
Easy to use but be patient . No pirouetting like a SA but easily managed
4,283
You cannot avoid the side scrubbing of tyre when you have a TA. They are almost impossible to turn if you are manually trying to position it. A caravan mover is a big assistance - Some single axle mover must not be used on TA's Follow the mover manufacturers adv
Some users of TA's swear they tow better, and that will be a matter of personal experience, but part of the possible reason is that TA caravans tend to be longer, and that can reduce some of the forces that contribute to instability.
When hitched, longer caravans (SA of TA) are generally easier to reverse around corners as the trailer is slower to try to jack knife.
Proper tyre inflation is just as important on both the car and caravan.
Nose load (A contentious issue) becasue of the geometry of the suspension and its interaction with the caravans centre of gravity, it's more important than ever to ensure your nose load is set correctly for the height of the tow hitch when the trailer is coupled.
5,165
We started off with a SA and then about 20 years ago we switch to a TA and never looked back. A lot easier to tow plus a lot more room inside especially if it is a 8' wide caravan.
On many sites, the roadways are gravel so scrubbing is not an issue and if using a AWD motor mover scrubbing is reduced significantly. It never bothered us. Many TA caravan also have an onboard tank. If we had to start again, I doubt very much if we would look at a SA again.
Sep 4, 2011
567
343
19,135
Over the years we have had many Caravans 5 berth 4 berth and 2 berth. Even the largest Caravan towed faultlessly and a single axle. Single axle is more easily moved when unhitched. Twin axles if on soft grass or gravel without movers on all wheels we have seen times the driven wheels just skid and dig in.. We personally have never seen the point of towing more weight around than needed. Main thing is the layout you like regardless of number of axles.
625
We have had 9 caravans so far, 2 were twin axle, the extra space inside is useful if you need it, the xtra size outside can be a pain on site, and depending on what your storage arrangements are, TA tend to mean extra costs, insurance, tyres, servicing,
As you are going from 2 berth I suggest you look at layouts first, find the one that suits you, and then look for the layout in TA and SA, sit in both, and then decide if the extra space etc justifies the extra cost, good luck with whatever you decide
