tyre pressure
When you findout what your MGW if you look on Here & have a look what size tyres you have on your van, you will be able to work it out.
Sproket.
as your van is a 2004 the tyres on it may not be what the van was originaly fitted with. my pagent had 195x95x14 reinforced tyres & is fitted with 185x80x14C rated tyres @ 50psi
having read your post it has now come to light that my manual is also missing so I can't tell you what your original tyres & pressures were.the original tyre size & pressures should be on the plate at the side of the door. try this link to the tyresafe website there is a chartfor most tyre sizes & pressures relevant to the axle load
http://www.tyresafe.org/data/files/caravan 08.pdf
]http://www.tyresafe.org/data/files/caravan 08.pdf
http://www.tyresafe.org/data/files/caravan 08.pdf[/quote
should read 195x75x14R sorry
correct 195x70x14r mtplm 1360kg 42psi which according to the tyresafe chart was the well out side the safety zone new tyres fitted as the original tyresize was not available except by Matador & no way would i fit those
