Tyre pressures and temps.
4,497
Got away from RMK, (Rural Milton Keynes) on route to Gwithian, Cornwall, With a stop at Peak view cl site Rooksbridge, BS26 2UA. FSP, £18 . Just south of Sedgemoor services. Lovely little local pub 10 minutes walk from the site.
Left RMK and watching the Tyre pal, left home both tyres at 64 psi and 17 ⁰c( doesn't happen often) once out of RMK and on straight road I noticed the tyre pressures were matched at 71 psi but the left tyre was showing 22⁰c and the right 24⁰c .
As we went through rain the tyre pressures matched, also the tyre temps matched with the 2 ⁰c difference. ie 69 psi, and 20 ⁰c /22⁰c.
Checked the next day,,and the reading matched the day before, the tyre pressures matched The right hand Tyre was 2⁰c above the left.
All I can think of is my cars exhaust is on the right hand side of the car. Giving the rise in temperature.
Anyone else noticed this.
Reactions: toad a caravan
3,465
It may be a minor difference in brake shoe clearance - or minor differences in the TPMS battery state of charge.
5,176
Could be a variation in the compounds in the tyre as have noticed this on many occasions even with the tyres on the car?
Oct 19, 2023
605
482
1,135
I doubt that its relevant in your case, but I've noticed a slight difference in pressure when the car has been parked with the sun on one side for a couple of hours. (I don't have temperature monitoring).
You do have quite a significant change in pressure though, 10 degrees C is supposed to change the pressure by 1 to 2 PSI, you're seeing much more than that.
4,497
I have always noticed a change in pressure of 5 to 7 psi cold to running, but never noticed a difference in temps. Except if the sun is on one side, it's just that every thing was identical before setting off.
4,290
We seem to lulled iso easily into a false sense of security when anything is "digitally controlled"
The differences reported in this thread might all be within the equipment's specified limits of accuracy.
Reactions: Danddandy and Hutch
3,465
I recall doing some consultancy work in the '80s for Otter Controls, who made fixed temperature thermostatic switches for the car industry - the switches couldn't be made with any level of consistency so every single one was tested and calibrated with wealthier car makers paying a higher price for a smaller range variation and the mass manufacturers paying a lower price for a much wider temperation variation.
Whilst I imagine the equivalent modern product has smaller numeric variations I'd expect the principle to be the same.
4,290
We were a customer of otter, and visited their buxton premises many times during 80's and 90's on product development. A great company to work with.
Even so ,if the sensors are selected, there will be a range conformance which some may be at the top and others at the bottom, and in the instances reported it's been a combination of temp and pressure which means each senor has to produce two different values, So pressure reading could be bottom range, and tem could be top range in one sensor and reversed in another, yet all fall within the designed range for the product.
Couple manufacturing tolerances, and the other variables such as solar heating, generally rougher roads near the kerbside, water, etc, etc ,etc and it is far from rare to find different wheels on a car produce un equal self heating and pressurisation after driving.
Sam Vimes
2,515
2,018
12,935
I've noticed that if my car is on a slope, side to side, then despite the air pump reaching the same pressure, when I drive off there's a difference.
May 30, 2024
99
115
635
With TyrePal, pressure is sensed quite directly by the device and should be quite a good indication of the 'real' pressure. They state an accuracy of +/- 1.5 psi, which seems pretty good to me. And means that you should try to be entirely relaxed about indicated pressures within 3 psi of each other.....
But I've always doubted whether the temp measurement is particularly relevant. Different parts of the wheel, tyre and air inside it will be at different temperatures, and the tyrepal sensor is in fresh air, just connected by the valve stem to the wheel. So its probably measuring the temperature of itself, and probably quite a bit cooler than the tyre once you're underway. Since generally I find the pressure increasing by about 6 psi after a while towing, that implies that the air inside the tyre has heated up by about 20 deg C, whilst in the same condition the tyrepal device might show an increased temp of about 10 deg C. So I'd say - don't pay any attention to the tyrepal temperature reading (unless it goes completely mad).
16
9
10,515
Hi, I have been running tyrepal for about 4 years now and yes even with the tyres set equally cold ( mine are 64psi) on the road pressures will rise due to friction through the tyre and wheel, mine were running at around 75/78psi only yesterday travelling back from Lincolnshire to Essex, pressures and temp do vary due to weather and time of year, tyrepal is not only good for monitoring tyre pressure and to give you ample warning to pull over safely if you have the unfortunate luck to pick up a slow puncture but also makes you aware of possible wheel bearing issues or brake shoes not adjusted correctly hence the higher temperature on one side. I had this issue a couple of years ago , when I had the van serviced by the mobile caravan engineer he found my brakes one side were not correctly adjusted , hence the higher temp ( previous serviced by Dealership ? ) all good now.
Reactions: Hutch and ProfJohnL
5,258
Achtung! Both fronts below recommended psi. Up come the individual readings plus the "flat tyre" warning light🙀. Outside it was 4 deg C. Told SWMBO not to worry. Hutch said its ok to drive. 5 miles later and a temp rise of 5 degs normal pressure was resumed.
I wonder how many would pump up the tyres or phone the AA etc😜
8,964
Just a normal occurrence as the seasons change over, and as you say nothing to get alarmed over. I tend to measure and adjust tyres in the afternoon after the sun as gone off of them and with cars leaving at least two hours from last use.
Reactions: Hutch and Dustydog
3,465
Pressures should be set with the tyre at ambient temperature - as autumn progresses the ambient temperature drops, which reduces the tyre pressure, neccessitating occasional top-ups - with the converse in spring.
In the circumstances you describe, the car is ok to drive but the tyre pressures should be adjusted as soon as practical.
I always adjust tyre pressures early in the morning, before the sun gets on them.
4,497
Well I am glad it did work, On the SF, I just get a low pressure warning, Not so long ago, I'm had a warning on one wheel . I had a small tyre pump, normally for my motorbike, in the car, and decided to try it out. It took the pressure from 29 psi, up to 33 psi, about 5 mins. Power bar was still 4 out of 5 so happy it worked. Tyres are 235/60/18 . I carry a car powered tyre pump as well.
